MECHANICAL ASSISTANCE NEEDED (advanced level misfire diagnostic)
Jeff7814
GA
Jeff
2016 Ford Mustang
I have a 2016 V6 mustang. Only while I'm driving the car will get a flashing check engine light and spike to 20 on the AFR gauge. It generates a p0300, p0301, and p0305 codes.
Current tests completed:
Coil swap from cylinder 4 to 5
Injectors cleaned and tested
Spark plugs replaced and gapped properly
Fuel emptied and replaced with fresh 93
None of those have fixed the misfire and I'm at a loss the car is heavily modified so ford wont touch it and because it only does it while driving I'm not sure what the next step should be.
If anyone has any idea's or questions ill do my best to answer as fast as possible.
W.O.T. Stang
Jim
2019 Mustang GT Premium PP1 401A
Do you have access to a good scan tool? What are your fuel trims looking like (short term and especially long term). This will point you in a direction as to what the PCM is seeing and adjusting for.
Have you done an in cylinder compression test as well as a relative compression test? Also if you have access to a good borescope with a side/wiggle lens - have a look inside the cylinders. Look for cylinder wear/coolant leakage/valve condition.
The fact that you are hitting 20:1 AFR (according to the PCM output) this points to an extreme lean condition which points towards a fuel delivery issue or too much unmetered air. Are you using the stock MAF? Has it been cleaned? If you have the misfire at idle check for a vacuum leak. But you state this happens while you are driving and this is much less likely.
Im sure others will chime in here as well, but trying to do remote diagnostics is tough, but hopefully we can point you in a direction to help.
Jeff7814
Jeff7814
GA
Jeff
2016 Ford Mustang
short and long term fuel trims are both pretty steady around exactly 1 the lowest I’ve seen is like.9 in the short and the highest I’ve seen is the long at 1.15 at startup
I haven’t done a compression test because my assumption was if compression was bad the issue would be constant and not coming and going
it’s a upgraded 3 bar ford oem map sensor that I also haven’t cleaned because I felt that would cause more universal issues rather then two random cylinders on seperate sides
I do really appreciate the help
SCP440
Oxfordshire UK
2019 Mustang GT, Jensen Interceptor, Ford Capri 3.0 Ghia
Coulld you have an injector going ? If you can get to the plugs on the injectors pull them off one at a time and see what difference it makes.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
You should do the compression test. You may have borderline situation that seems ok at idle but goes out of tolerance at load.
Also, please fill us in on what “heavily modded” means.
volvofan94
Midwest
‘21 F150 XLT FX4, '19 GT350
Potentially a roller cam follower on the bank 1 side of your engine is wearing out and not opening the intake valve for the correct duration. It looks like the V6 and V8 engines share the same TI-VCT design. I'm guessing your car has roller cam followers and one or maybe 2 of them are out of spec because the roller ball bearings inside the follower have wear on them.
My Mustang had a similar problem; difference was the car had a misfire in cylinder 6. I was hoping for an easy DIY fuel or electrical fix, but after taking it to my local Ford dealership, they found the cam follower was out of spec. The dealership replaced them and the car is running fine ever since.
Jeff7814
Jeff7814
GA
Jeff
2016 Ford Mustang
Heavily modded means:
DW400 Fuel pumP
FIC 1000CC injectors
Boundary billet oil pump gear
Manley billet pistons
Manley forged rods
King performance main and rod bearings
ARP Head studs
1 Step colder NGK spark plugs
Precision 6766 turbo
Ford OEM 3bar MAP Sensor
and probably a few other small things im forgetting
Jeff7814
Jeff7814
GA
Jeff
2016 Ford Mustang
Anyone can feel free to correct me if i'm wrong but i believe because of the way it misfires its not possible for this to be a mechanical issue. The misfire only happens when i'm driving the car doesn't misfire and then stay running two cylinders down if i continue driving or pull over the car will recover on its own.
It also gets a flashing check engine light but that goes away when it recovers. I think its hitting some kind of safety and cutting fuel to the cylinders but im not sure how to know what that saftey is or how to fix it
Its also worth mentioning that while its misfiring the Short term fuel trims lock at their current value while when im driving the car it regularly moves by .01 up or down multiple times a second
horsepower addiction
Arizona
Nate
s550
You need to move the injector and coil of the bad cylinders to a good cylinder and see if the code follows. Then you will know if it is one of those. If not then a leak down test and compression test
Jeff7814
Jeff7814
GA
Jeff
2016 Ford Mustang
I put in the intial post that I swapped the coils and that the injectors were tested...
Not familiar with the 6 Cyl, however does that engine have a cam or crank position sensor (or both)? These are known to prematurely fail and sometimes without throwing codes. When they do start to fail, it will be similar symptoms like misfires, hard start or in extreme cases, the car will die when driving.
If it has one or both, pull them and check the connector that goes to the sensor. Check the harness to and wires hidden in the black conduit for any damages. Rodents love chewing up modern engine harnesses. I would also probe and ohm spec each sensor and see what the benchmark readouts are on either. You can test with them off the engine. If the readout you get is +/- significant value when compared to the actual Ford allowable value, the sensor is junk and needs to be replaced.
2 other sensors that can cause misfire:
- Mass air flow sensor. Make sure again that the connector is not loose or damaged, check the wires and make sure it’s secure where it’s mounted. Check tour entire air intake tract and also make sure there are no breaches (clamps are all tight and hoses are pushed on solid and secure).
- temp sensor. On the Coyotes this is the CHT sensor. If it’s getting failing and producing false readings it’s going to cause drivability issues.
Again rodents love wiring harnesses; check all your harnesses under the car near the engine bay and any in the engine bay for any damages. Also I know you swapped coils, but check those connectors too and make sure not only is the connector locked onto the coil pack, but make sure the pins in the connector aren’t damaged and the connector isn’t loose from the harness. There’s been quite a few instances on here with S550 owners finding that either the connector was bad (loose or damaged) or the harness going to it was damaged in some way.
Report back your findings
