skytop1
- Nov 2, 2015
- Boynton Beach, FL
- Shelby GT500
Good evening David: I will call you tomorrow. Thanks
The thud noise problem is caused by a poor design of mounting the rear diff in the IRS subframe. Impulse s energy from the transmission to the rear diff to the IRS subfrane and then to the main frame is the cause of the problem. You hear it a very low frequency reverberation thud of the subframe adn mainframe throughout the car. It is a single low booming sound emanated from the rear of the car. You will hear one thud boom for every shift. You don't have to be moving either. Standing still, just put car into gear and you will hear it. It doesn't happen every time due to how your sub frame is aligned. The initial impulse is generated by the spinning transmission input shaft through drive shaft to the rear.
Ford acknowledged the problem but outright refused to repair it. I ultimately researched and found the fix and had the repair done. Finally, no thud boom at every shift.
Care to share what you had done to your car !![]()
Used Steeda urethane red bushing inserts on the mounting of the differential 555-4439The fix???
Sent from my SM-G920V using Tapatalk
Red vs. Black, can you share the pros and cons of each?He installed our differential bushing inserts which resulted in a substantial decrease and near elimination of the thud.
Sent from my VS986 using Tapatalk
Sure, the red is 80 durometer and the black is 90 durometer - the higher the durometer (or stiffness), the better job it's going to do regarding preventing the differential from moving. The higher the durometer, the more likely you are to notice an increase in NVH - although you'll get increased performance as a trade-off.
