skytop1
- Nov 2, 2015
- Boynton Beach, FL
- Shelby GT500
Red is a bit more compliant and best for street use. Black is less compliant (quite firm) and are best for drag racers. Actually, there is a third type made of solid aluminum for hard core racers. Any you choose, really secures the differential.Red vs. Black, can you share the pros and cons of each?
Sent from my VS986 using Tapatalk
The kit I gave part number for comes with both a red and black kit so you have your choice. David Steeda recommended the red for my street use (the least NVH) and that is what I had installed. I hear no NVH at all and the thud boom noise is almost gone. The IRS subframe alignment slugs give the subframe positive contact with the main frame and ensure proper alignment. Ford only relies on a bolt to hold the subframe. What thud that does occasional occur is significantly reduced in intensity. This is a muscle car which is going to make some noise. I have the stock GT exhaust which as you probably know is way (too!) quiet.
