shanewendel
- Sep 27, 2019
- Buckner, KY
- Shane
- 2017 Shelby GT350
Would this slight seepage indicate anything?
See the last two posts in the GT 350 Basics sticky for info and tests on your P0192 DTC.You have a bit different circumstance than I do but are you able to log fuel pressure by chance? I have a P0300 as well but it came with a P0192 and no other misfire code. I get intermittent loss of fuel pressure - down to 0 then returns to normal - under load. I don't think our issues are related but I'm still curious.
Thanks but see first post, already did that.Could also be a bad coil on that cylinder. Audi used to have issues with bad coil packs doing the same thing. Iād also switch the coil packs around. Take number 7 out and check the impedance, it may have a crack in the housing or bad innards.
Not yet, watching the A&M game!Have you swapped injectors and coils to different cylinders yet?
Turned out better than I was expecting!Not yet, watching the A&M game!
Can I just unplug the IMRC solenoids to check for IMRC issues? Not sure which way they default or if they are designed the same way as the 5.0.Have you swapped injectors and coils to different cylinders yet?
