Mach 1 Front End Clunk at Zero G's
17MagMetal
San Francisco
Michael
17 Mustang GT, 07 Ford Taurus SE, 95 F250 Xlt
lol, if you haven’t tried this at least once before you acquiesce and buy a dam strut/spring compressor…we cannot be friends 😂
If that’s you, you’re ballsier than I!
We’ve got other economy cars in the family that I’ve got springs onto just pressing it all together with the strut towers and LCAs LOL.
wingnutt
@FL410
michael
350R Procharged w/P1X
LoL, that one was not me…not saying I haven’t tried it in another form, one time in a galaxy far far away 🙃
TrackMeisterWannabe
TrackMeisterWannabe
2022 Mach 1 w/HP
It could be the upper strut mounts.
This SSM was released for the GT350's regarding a front end clunk noise. Just because the SSM is for a GT350 doesn't mean the problem can't exist on other platforms:
https://www.mustang6g.com/forums/threads/ssm-50672-front-end-“clunk”-or-“pop”-noise.176357/
Also the front strut mounts have been known to fail prematurely, causing a clunk noise from the front end:
https://www.mustang6g.com/forums/th...your-upper-front-strut-mount-bearings.130986/
Took the car in to the dealer today. The local tech referred to SSM 50672 as mentioned by CJ above. I now have to bring the car back when I can leave it for a few days so the tech can pull the struts and check the strut mounts. I then have to wait for the parts to arrive...
Did I mention that I hate it when other people bend wrenches on my cars?
TeeLew
So Cal
Tim
There are not that many tools or fasteners involved. Get under your car and retorque them like a big boy.
ChitownStang
Chicago, North Shore
2021 Mach 1
Are you talking about tightening the strut mount bolts without removing the spring? You’re saying it could be the fix to the clunk?
17MagMetal
San Francisco
Michael
I’ve heard that is a fix. I’d just buy and slap an isolator on then torque the strut bolt properly to end the saga.
ChitownStang
2021 Mach 1
I don’t know what an isolator is?
Can I get to these bolts by removing the tire or more is needed ?
Also anyone know the torque spec?
Sorry for my ignorance.
I’ve already removed the entire belly pan looking for a loose oil cooler mount that someone suggested but mine was tight.
17MagMetal
San Francisco
Michael
it’s basically just a stupid rubber piece that prevents movement/noise between the spring and tophat.
you can try to torque the bolt without removing anything, pop hood and torque that strut to whatever the spec is (brain tells me it’s 40 something ft/lb but I can’t remember).
17MagMetal
San Francisco
Michael
It sucks but your car is nice enough that I’d just let the warranty do it’s thing.
You might try and just crank on the bolt a bit and sit if it silents everything but if you’re warrantied I’d let them solve it.
TeeLew
So Cal
Tim
I'm taking about tightening whatever is loose. You won't find it by clicking a mouse.
ChitownStang
2021 Mach 1
Ok, I was referring to the strut mount for now.
Checking every bolt on the front end of the car may be above my pay grade .. 😝
TeeLew
So Cal
Tim
It's not. You can do this. Buy a basic tool set and a couple big sockets from Home Depot or Harbor Freight. You'll spend more time taking it in that just giving it a wrench rattle yourself. You'll actually feel a lot better about the fix, as well.
If you give it a shot and don't find the problem, then, by all means, give it to a pro. I'm going to encourage you to have a go at it, though. At the very least, when the pro tells you what the issue was, you'll understand what he's talking about better.
