Lowest Maintenance Most Reliable FI
engineermike
La
2018 GTPP A10
Nice. I know, different gen Coyote but what baseline (pre-adjust) spark advance do you use with “OA” off and on?
I haven’t experimented with turning on OA. However, looks like it’s commanding 14-15.5 borderline timing at WOT and it can add up to 4 deg if no knock is sensed. I’ve only seen it able to hit max timing when using a good dose of Boostane.
schmeky
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
So far the Procharger and Whipple have the best recommendations.
Jordanfmeyer
Manhattan, KS
Jordan
2017 Shelby gt350
Procharger. Bolt on kit that makes solid power with plenty of room to grow.
schmeky
schmeky
David
Stymee,
Would you take the Whipple over the Roush?
ahl395
Allan
I love my Procharger but Whipple will have less maintenance. Centri's need the oil changed every 5-6k miles. Whipple only needs it every 100k IIRC
SolarFlare
S. Fla
2015 CO GT
Guess going that route we can say whipple has a water reservoir and relies on a pump to move said water. Which means more active systems that can fail.
engineermike
La
2018 GTPP A10
So you have to change centri oil twice per engine oil change? That kinda sucks...
ahl395
Allan
True. More points of failure. Less regular maintenance though which is what I thought OP was worried about.
I change both every 5k. If your car is supercharged there's a good chance you don't want to wait 10k anyway lol
SolarFlare
S. Fla
2015 CO GT
If you race a car I don’t wait for 5000 mile oil changes. So I don’t wait for 5000 mile blower changes either. I change my oil every 1500 miles and since I’m down there I change the blower oil
JPSTANG
MN
Joe
2017 Mustang GT
My vote for ProCharger, can we really even call it maint to change the oil in it. i mean really, i can do the car and the blower in under a beer if i wanted to. besides if it were to brake i would also have less chance of stuff making it in the intake and most likely drive it home...
fuelforfire87
IL
2014 Shelby GT500
Changing the oil in a self containted blower like vortech/paxton or procharger is super simple, just do it every oil change and it literally only adds 10 minutes to the process. Or if you are really lazy just get an oil fed blower like on some of the higher end vortech/paxton units
engineermike
La
2018 GTPP A10
I only use oil specifically designed for high performance engines and long change intervals. If you have a supercharged coyote, you really should consider the same. If the oil is designed for it, then there is only detriment to changing it early.
Jordanfmeyer
Manhattan, KS
Jordan
2017 Shelby gt350
Procharger states oil changes need to happen every 6,000 miles. It’s seriously as simple as it gets and easy. That’s the only maintenance on a Procharger unit.
