Low fuel pressure Rough idle
Rapid Red
Woodstock GA
Greg
Stalling was there before the tune? That almost sounds like there is something going on with the converter.
Example
High lift cam
Stock converter
Car stalling at idle
Fix replace converter having a higher stall.
Another way of saying it, the converter is not going into neutral.
Dragging like a clutch, auto trans is never really in natural, it stalls.
Not having enough stall, slows the RPM down engine stalls
Buy the car new, have you ever had the trans serviced?
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
Ford Mustang GT convertible premium 2018
Example
High lift cam
Stock converter
Bought the car used haven’t service the trans yet
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
Example
High lift cam
Stock converter
Stalling was before all of that yes
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
So you think it’s the auto trans converter?
You had low fuel pressure and lean codes. Replace the fuel pump.
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
I did get code P061A back in July of last year related to torque converter performance and I never got that code again so you might be right I do have an extended power train warranty but I don’t know how to explain this to the service advisor
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
But than how would the low fuel pressure code have to do with any of this
P061A is a torque calculation error, not a torque converter error.
Fuel pumps last around 100K using gas. You have e85 so it is working harder.
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
You think that would cause me to idle rough and cause my car not to move correctly when cold starting
Does the P061A code set again after you clear it?
Rapid Red
Woodstock GA
Greg
I would get the trans serviced see where it goes from there.
Autos need to be serviced, there is a lot going on inside. Valving, small fluid passages, can trap trash, clutch partials, has a filter. Transmission serve for your car is more critical than my ol 6sp.
60k, I would think it is due, I would not try to explain anything getting it serviced. Just ask to have it done, one of three things could happen.
1 runs fine
2 gets worse ( a good thing) no need to fight for the repair
3 remains the same
With such an intermittent problem, the process of elimination applies.
E85 and fuel pump wear, I seem to remember something about that. Dan could be on to something.
I remember not only was the fuel hard to find, there were other things about it that holds me off.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Fuel. Pump.
nicolasfinta1
nicolasfinta1
Los Angles
Nicolas
Autos need to be serviced, there is a lot going on inside. Valving, small fluid passages, can trap trash, clutch partials, has a filter. Transmission serve for your car is more critical the my ol 6sp.
1 runs fine
3 remains the same
The thing is with the issue I have no lasting check engine code they all go away and it’s sucks cause it doesn’t leave me with much
