Looking for definitive answer on GT vs GT350 Half Shaft differences
Scootsmcgreggor
CA
2016 Ecoboost turned GT
gt350 axles are longer on both sides, IIRC about 3/8". Prob for the brake drum mount thickness. They also don't use the thrust washer. So if you go gt350 axles on your GT, don't use the thrust washers and they fit.
GTP
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Al
Also helpful to know.
But what I really need to know is if my GT axles will fit a GT350, since I will be replacing my rear knuckles and e-brake for the 350 setup. Will mine be too short?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
No. The splines length and diameter are the same on both the GT & GT350. I think your only problem will be the camber being to positive.
Scootsmcgreggor
CA
It would stretch the axles a bit most likely, and could tear the boots as a result. Boots are not replaceable, would need a whole axle.
I removed the thrust washers on my GT and the axle cv’s had to extend a bit due to lack of thrust washer thickness. Blew an axle boot first event out.
GTP
GTP
Deutsche Pony
Indy
Philip
Interesting, more good info to know.
The 350 knuckle/hub will be pushed out 8mm per side. Certainly more than the thickness of a thrust washer!
shadowx
Missouri
mustang gt premium 2019
So better stick to the OE gt driver axle if broken or get the gt350 one?
beefcake
Bethel
2018 Ford Mustang
DSS or Gforce would be a better bet
Gforce won’t sell individual axle though, but we will sell the dss individually if you just wanna replace individually
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I recently broke my driverside axle. I found a gt350 axle cheap. It fit just fine. The shaft itself is stronger, the GT is hollow, the CV joint is the same. I doubt it is much stronger due to the CV joint.
shadowx
Missouri
I'm between the OE gt or the gt350 axles if I would like to choose for my budget, what's the better option?
K4fxd
NKY
The GT350 is a solid shaft the GT is hollow. They both have the same CV joint.
I snapped my driver side axle and when I took it apart I also had significant wear in the CV joint. I found a used 350 shaft to use as a stop gap till my budget allows for good shafts.
If it is not broke right now wait till you have the cash for the aftermarket ones.
beefcake
Bethel
2018 Ford Mustang
the gt350 is a little better than the stock.
if you’ve broken one and are on a tight budget, then it’s a better option but we typically recommend Gforce or DSS if you’re going to be getting after it a lot at the dragstrip
shadowx
Missouri
I have a daily gt and won't drag it any time soon.
I also dropped it off at a dealer and they said need to replace the driver axle and the wheel bearing. Since I have a clunking noise when engaging R to D or vice versa. Also I get some vibration in the rear when turning in either side.
So I either save around $150 for just getting OE for the D side axle and wheel bearing or getting the gt350 but will pay the double for the labor if I choose that.
K4fxd
NKY
Double labor? That makes no sense.
beefcake
Bethel
2018 Ford Mustang
let me know if we have them off
