List of changes to the 2019 GT350
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
I did not see on the list so here it goes: 2019 R (and maybe base - no idea), has no clutch helper spring so clutch action is perfect out of the box.
I have noticed a difference in the clutch action on my 2019... no steeda replacement spring needed.
mrbillwot
Greater Boston Area
Bill
'19 Kona Blue w/blk roof & blk stripes GT350, 89 LX5.0 Sedan (Mustangs Past: 69's Coupe, Mach 1, & GT)
They wont even sell you one (its how I learned of the MY2019 spring design difference last summer)
Erik427
Huntington
1979 Mustang
Here are some changes for the 2019 GT350. If you have better information post below and I will update this list with your corrections/additions. I have seen several posts asking what changed on the 2019 and they mostly cover the new engine block.
1. new 19-inch wheel design (base)
2. Michelin Pilot Sport Cup 2 (not same as R)
3. chassis has been tuned (Base)
4. 10 percent stiffer front springs (Base)
5. rear, the coils have been softened by 6 percent (Base)
6. stiffer anti-roll bar (Base)
7. MagneRide dampers also have been re-calibrated (Base)
8. ABS re-calibration, provides stronger clamping force (Base/R)
9. 1.09 g of lateral grip ( up o.o7) just shy of the R’s 1.10 (Base)
10. smooth-faced brake rotors (Base/R)
11. GT350R's smaller grille opening (Base)
12. Gurney flap ups the down force on the rear of the car to 238 pounds (from 135 2019 or 186 outgoing wing.) (handling package) (Base)
13. adjustable strut mounts (handling package Base) (Standard on R)
14. revised electrically assisted steering (Base/R)
15. 60 mph in 4.0 seconds, 0.2 seconds quicker, a tenth behind the lighter GT350R. quarter-mile 12.3 seconds at 119 mph. (Base)
16. optional dashboard exposed carbon fiber (Base/R)
17. 12-speaker Bang & Olufsen stereo system (technology package) (Base/R)
18. blind-spot monitoring (technology package) (Base/R)
19. cross traffic alert (technology package) (Base/R)
20. heated exterior mirrors (Base/R)
21. Puddle lamps (included with tech package)
22. No longer installing a red start button. I think the start button is now a stock GT button.
23. Changed seat trim and width.
24. added rubber coating to the engine to trans plate. (stops vibration noise)
25. Newly designed door panels, a standard machined aluminum instrument panel appliqué, and a wrapped center console
26. No longer installing a clutch helper spring.
Engine Changes (adding these because of a request)
26. new 5.2 block (Base/R same)
1. head bolts
2. additional material block and heads
3. valve seat material
4. head gasket
for more engine information follow this link. (link provided by lenFeb)
https://www.mustang6g.com/2019-voodoo-engine-changes-confirmed/
Note: comments provided about performance improvements for the 2019 GT350 being based on new tire.
Would like some more info about the heads?
Thought they stayed the same......
sox3
Newark, Delaware
George
2019 GT 350 Performance Blue
Maybe this will help.
Confirmed Changes
Overall
  • The Gen 2 5.2 can withstand 12 psi of sustained boost (Confirmed by article)
  • Romeo Niche Line engines are now only built by a single builder (Evidenced by 2019 Build Plates)
Recast Block
  • Longer Gen 1 Coyote spec head bolts (Confirmed by article)
  • Additional cylinder bore material surrounding the water jackets (Confirmed by article)
  • Added cast in brace on intake side of cylinder bore (Confirmed by article)
  • "Bay to Bay" Breathing ports reorientated to better equalize block gasses and minimize windage (Confirmed by article)
Recast Cylinder Head
  • Additional material around water jackets for better sealing (Confirmed by article)
  • Stronger valve seat material to handle increased heat (Confirmed by article)
  • 4 Layer MLS head gasket (Confirmed by article)
Valvetrain
  • GT350R Timing Chains (Confirmed by article and data tag)
  • GT350R Lash adjusters (Confirmed by article and data tag)
  • GT350R Cam covers (Confirmed by article and data tag)
  • GT350R VCT mechanisms (Confirmed by article and data tag)
Rotating Assembly
  • Improved I-beam connecting rods (mrbillwot called FP Hotline)
  • Forged crank sprocket (mrbillwot called FP Hotline)
Unconfirmed Changes
  • Copper-lead bearings
  • Resized piston-cooling jets
  • Improved oil pump with larger stronger gerotor gear - FP Hotline said "carryover" (mrbillwot)
  • Upgraded exhaust valve seals
  • Higher exhaust valve spring rate
  • Improved Oil Pan, Oil Pickup, and Windage tray - mrbillwot confirming
Sources
Frank.Herbst
Frank.Herbst
Denver, CO
Frank
2019 GT350
Confirmed Changes
Overall
Recast Block
Valvetrain
Rotating Assembly
Unconfirmed Changes
Sources
I'll add this to the OP and let everyone comment.
Thanks.
PP0001
Both Sides of the Border
2021 CTR LE (126 & 581)
One other change for the 2019 model compared to all of the previous 4 model years is the absence of being able to order a "920A Base R Model" for 2019.
This model was available for all of the previous years namely from 2015 thru 2018 but not available for the 2019 MY.
:sunglasses:
Frank.Herbst
Frank.Herbst
Denver, CO
Frank
2019 GT350
:sunglasses:
Updated in OP.
Thanks.
ssyellow
Michigan
15' Competition Orange GT - PP/Recaros
The 2019 models are on the edge of my budget currently. With all the above said, have the 2019 engine upgrades contributed to a significant improvement in oil consumption/engine issues the earlier GT350 model years had?
Frank.Herbst
Frank.Herbst
Denver, CO
Frank
2019 GT350
Very hard so say for sure. I only have 100 miles on my 19 but my 17 didn't use oil. I think there is a general hope that Ford addressed some of the part issues. But buying a 15-18 could save money and be a great car. Having a warranty is probably good insurance.
I think most of the guys with some miles on their 19s are doing fine but no car line is 100 percent free of a. problem or two.
03reptile
2019 Shelby GT350
6K on my 2019 and no oil usage or issues.
wjs
2020 GT350; Previous: 2017 GT350, 2016 GT350, 2012 BMW 135i
Can anyone comment on a possible reduction in piston slap with the 2019 improvements? Oil consumption and piston slap are the two most significant issues that I’ve heard of and/or experienced.
