svttim
On the base model. The Gurney flap in obviously not available on the R. The strut mounts are standard on the RNumbers 13 and 14 are incorrect. They only come with the handling package.
You might be right. Wish Ford provided more information. If you find an article with more updated engine information post the link here and I'll add it to the OP. I also keep looking for more info.Great list! Thanks for putting it together.
I could swear that for the engine updates, Ford redesigned the pistons and rings for 2019. And the original style pistons and rings are no longer available from Ford.
Will update, Thanks.On the base model. The Gurney flap in obviously not available on the R. The strut mounts are standard on the R
Well, then along with tires you need to tune suspension, stiffen front by 10%, stiffen anti-roll bar, etc..... for pre 2019.
Slight renumbering, this should be correct now for 12 and 13. Both show the handling package.Numbers 13 and 14 are incorrect. They only come with the handling package.
ThanksI believe the puddle lamps were new on the 19's also.
I will add it, you guys don't miss muchMinor, but they got rid of the red start button, and they changed the spring on the clutch pedal.
Yep my 19 with the up-graded seats has the rubbing issue. I put silicone lubricant on the side of the console and after two weeks, no more squeaking noise. It's not visible and will not damage the material of the seat or the console. Win-win!Seat trim also changed.
Although the order guide doesn't list it, it appears that they widened the seats as well, hence the reason so many people are complaining about them rubbing against the console.
Mine too. Haven't figured out for sure if it's the console or the seats that were widened, but will be experimenting to find a solution soon.Yep my 19 with the up-graded seats has the rubbing issue. I put silicone lubricant on the side of the console and after two weeks, no more squeaking noise. It's not visible and will not damage the material of the seat or the console. Win-win!
I'll add to OP. ThanksSeat trim also changed.
Whether its the seat side bolster or the console, it really doesn't matter. I spoke to my SVT technician, who I trust implicitly, and he indicated there was no lateral adjustment for the seat or the console. Our weight on the seat also contributes to the eventual widening of the seat area, as well. I used a silicone lubricant (similar to heavy Vaseline) applied on the left lateral lower side of the console where the seat is rubbing. It will not damage either surface and it stopped the noise immediately. I think this is the best solution, and after applying the thin coat on the console, I've had no noise. I use the feature that moves the seat back when you turn off the engine, so it get a lot of use going forward and back when I enter or exit the car. I did this two weeks ago and no more noise. I think this is your best option.Mine too. Haven't figured out for sure if it's the console or the seats that were widened, but will be experimenting to find a solution soon.
I'll add to OP. If anyone has corrections to any of the items listed please provide and I'll update. Thanks.I believe 2019 was the first year that the rubberized coating was installed on the engine block plate to prevent the rattling sound. My 2019 has the updated block plate.
