Line lock
stevnoof
new jersey
2016 mustang gt base manual 3.31
When using linelock, after the brake is locked and you have 15 seconds to do your burn out, if you start doing your burn out and then press "ok" to unlock the brakes before the 15 seconds is up will the car start moving forward or will it shut down the burn out completely?
If not will the car roll forward after the 15 second timer is up?
I don't want to look like a fool at the strip tonight and drag water down the track. Manual trans.
tyguy
illinois
2016 gt
I activate the line lock, and once the 15 seconds start, i start the burnout til i see some smoke, (only takes a few seconds) hit the ok button to release the line lock, all while still on the throttle for a little bit. This allows me to finish my burnout with a slow roll forward, then let off in time before reaching the staging beams.
So yes the car will start rolling forward when you hit to ok button to release the line lock, as long as your on the gas.
clevernickname
BC, Canada
2015 Magnetic Mustang GT, 2016 camaro ss (gfs), 2015 range rover sport, 2013 ford explorer, 2017 WRX
I swear I did this once and I pressed ok and it cut off all gas and I just stood there like an idiot. Maybe I need to test more.
