TheLion
I'll give it a try this weekend and see what I can come up with and post back what I find.You should be able to log both Inlet Air Temp (IAT1) at the filter and Charge Air Temps (IAT2) going into the throttle body with your Actron. In most cases, if you can monitor IAT1, then you can also monitor IAT2.
There's also the Bluetooth ELM327 modules with which you can monitor loads of PIDs with apps like Torque from the Google Play Store. I had an ELM module and it worked pretty well. You could definitely monitor IAT/CAT with it.
