Level of difficulty?
Discussion in 'Transmission & Drivetrain' started by poncho@home, May 10, 2018.
  1. poncho@home
    poncho@home GettingOld
    Vehicle(s):
    2017 Mustang GT Premium
    Sep 19, 2017
    Laval, QC
    220
    66
    0   0   0
    I have the GT350 half shaft kit and was wondering if I should do the install myself or not. Dealer is quoting 3 hours labour, so I figure I can get it done in 4-5?
    I have a compressor and can get an impact, but how difficult is it to do on the floor using stands and jack vs a lift?
  2. whatsup62
    whatsup62 Well-Known Member
    Vehicle(s):
    2015 Mustang GT PP
    Sep 16, 2015
    Jupiter
    1,630
    315
    Rating:
    100%
    4   0   0
    Pretty easy really...some have half shafts pop right out like me, others spend half a day getting them out.
  3. ctandc72
    ctandc72 Well-Known Member
    Vehicle(s):
    '17 Base 6 speed 3.7
    Nov 1, 2017
    VA
    704
    226
    0   0   0
    Pretty easy on jack stands...I did my rear end swap (you of course have to pull the half shafts and then install them into the new rear end) on jack stands with no issues.
    Two pry bars made quick work of popping my half shafts out of the rear end, but I've read where other people have had issues. In that case, you can get a loaner tool from the local parts store (two tools actually) one you need a slider hammer, then an attachment that goes on the slide hammer than is used on the axle shaft to pop them loose. Had to use that setup on a car before. Took no time to pop them loose with that setup.
    Here's a picture of what I'm referring to:
    https://www.amazon.com/OTC-7509-Inn...=2025&creative=165953&creativeASIN=B000O825QU
    Good reference video here:
    [ame]
  4. Logan@Lethal
    Logan@Lethal Well-Known Member
    First Name:
    Logan
    Vehicle(s):
    2014 Turbo GT/CS
    Oct 30, 2017
    Tampa, FL
    116
    30
    0   0   0
    Beer, patience, and a friend! You can do it on either stands or a lift, honestly.. Lift always being easier when not under the hood.. even then, still awesome.
  5. 2-tone
    2-tone Well-Known Member
    Vehicle(s):
    15 mustang gt m6
    Feb 9, 2016
    Cincinnati
    127
    27
    0   0   0
    It's a pretty easy job.
  6. DarkHor$e
    DarkHor$e Well-Known Member
    First Name:
    Vehicle(s):
    RaceRed '17 PP Base
    Apr 3, 2018
    SF bay area
    123
    FK that, I'll just have to live with mine.. lol...
  7. Bartly
    Bartly Well-Known Member
    Vehicle(s):
    Oct 25, 2015
    Out West
    1,423
    173
    0   0   0
    So I have a question. I've never seen where you install a c-clip onto any sort of shaft before the shaft is in it's seated position. How does this work with axle shafts. Does it only interface with something other than metal, something flexible that allows it to slide in and deflect something into place? Or am did I see it wrong in the video?
  8. ctandc72
    Vehicle(s):
    Nov 1, 2017
    VA
    704
    226
    0   0   0
    The clips sit in the grooves on the end of the axle shafts and are 'captured' by a similar inside the axle / housing once you seat them. Just about every CV / half shaft I've dealt with is like that.
  9. Bartly
    Vehicle(s):
    Oct 25, 2015
    Out West
    1,423
    173
    0   0   0
    Thanks. When I mentioned shafts I should have said every type of shaft than a half shaft, lol. Actually never worked on one. I remember a Dana35 solid Jeep axle where you slide the shaft in, then install the c-clip once the groove in the shaft is past the flange in the housing. Also was thinking similarity of u-joint caps where you push them on then install the clips. Was just curious how the clips hold the shafts in if you can pre-install them. I suppose since they can be pulled out with a slide hammer and it sounds like sometimes the clip remains installed, the interface must not be as tight as the Dana 35 I worked on. I guess it will make perfect sense after a person has installed them, which I obviously have not. Anyway thanks for the reply and letting me know it’s the way they all are.
Loading...
Share This Page
