Lethal H-pipe drone issue
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Curious if anyone else has the Lethal H pipe and is experiencing drone with it? I get drone between 1500-1600 rpm and it’s quite pronounced. It’s annoying enough that I put the car into manual and up or downshift.
I’ve also notice a warble drone, in which holding a steady RPM I’ll get a drone that comes and goes at random. Not sure what that’s about.
I didn’t notice any issues after it was first installed so I suppose I should get under the car and make sure the welds are all good and no leaks are happening cause this thing is now resonating the body panels in the car when it drones. @LethalBlake @LethalPerformance
Mspider
Michigan
2022 GT
Which mode is your exhaust set in?
silverbullet85
San Diego
2019 Gt
Look underneath maybe a clamp is touching the body underneath
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Are your tips flush with the bumper cover?
Mine droned until I extended the tips about 2 inches out from the cover.
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The h-pipe is welded onto the rear section but I’ll take a look at the front connection.
Mine are slightly extended from the bumper cover.
oregongt350
Oregon
Michael
2022 GT500 HE, 1967GT Fastback S code,
No judgement here, but it amazes me, I’m a old fart I can’t imagine making one of these louder than they already are. !!!! My GT350 sent me to the audiologist with ringing in my ears, no joke.
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The goal wasn’t to be louder, just to change the tone. I don’t ride around in track mode all the time lol
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Me thinks the sound is about harmonics and at right around two thousand RPM, they all seem to add up to "the drone." It isn't noticeable if you rev right through the range but, if you hang there, at least on my girl, (X pipe) you get the unwanted sound.
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Seems like any X or H will drone around 2K RPM, I hate that "boomy" sound and yes with tinnitus the drone is horrible! My solution... one Vibrant resonator in the drivers side of a Summit H. Still keeps the volume but cuts down on the boom.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
Mike, do you have any sound clips with this setup?
Mikepol2
Pittsburgh, PA
Excelerater
Memphis TN
2015 GT
Stock active exhaust. Startup in normal mode, switching to track and then quiet with little throttle blips.
That is a nice ride.
You changed the design of the OEM excust by adding the H pipe?
You arent the OP so im confused now
Gt350s and 500s come with H pipes,my ride also has an H pipe (no drone)im surprised
the MACH1 does not have one from the factory
