Kooks green cats
engineermike
La
2018 GTPP A10
That's what MAC suggests. There is room under there to cut it off with a Sawzall or a chain cutter. Mock up the exhaust pipe/flange, tack it and the tig the inside.
That 4xx steel is pretty hard to work with. It’s hard to cut with a saw due to hardness and work hardening, and I couldn’t imagine even trying to fit a recip saw in there to get a good square cut. FWIW it cuts easier with abrasives like a cutoff wheel. Then the remaining stub isn’t round and again, the material isnt easy to form. I know doing this job on a workbench is difficult due to the geometry and material properties. Doing it in situ just seems like needless torture.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
Yes, I used a zip disc on an angle grinder to splice the Gsport cats into the 2M Fab pipes (3 inch 304 stainless). it definitely was a bitch cutting the tail pipes off with a sawzall for the x pipe and I think that is aluminized steel, but I could be wrong. Might be 409 stainless like everything else.
