Kooks 2 inch Headers
Ransom
Tn
Jonathan
18 Mustang GT, 09 Challenger Srt8
Thinking about picking up a set, but wanted to see if anyone had any issues with installing them or clearance.
andrewtac
TX
mark
F250. 2020 GT 400A
In for the info currently 1 7/8 and did pretty much everything else.
Ransom
Ransom
Tn
Jonathan
Surely, someone has installed these.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Unless you’re going to drag race only and make 1200+whp, 1 7/8” is more ideal.
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
I'm NA and have 1.75 Kooks, very happy with 'em.
AZlb5.0
Arizona
Carlos
18 GT Premium
What are your future plans with the car? Staying NA or doing some type of power adder?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I've seen back to back dyno runs that show no loss of torque between the 1-7/8 and 2 inch on a stock coyote. HP was slightly higher due to shifting up in the RPM range.
Ransom
Ransom
Tn
Jonathan
I understand how header primary/secondary, diameter/length can effect hp/tq.
The car may stay NA but may go boost down the road, havent made up my mind yet.
I would rather move peak torque up higher in the rpm band.
GregO
Illinois
S550 GTPP
That’s mostly 2 valve header dynamics.
4 valve not so much.
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We ran the 1-7/8" Kooks headers on our 2018 GT project Goldmember. No issues with installation at all. We've sold a ton of the 2" ones to our customers over the years and not once have I heard of any issues with fitment from our customer who installed them.
My personal take on it is that 1-7/8" is great for NA as well as boosted setups. Goldmember was powered by a Gen5 3.0L Whipple and was making around the 1100rwhp range. I went 8.64@157 in that car. I don't believe at that level that we would have seen any significant increase in performance with the 2" ones. With that said the only time I really recommend the 2" headers is if you're going for an all out race setup and are looking for every bit of power possible. Otherwise the 1-7/8" work great even for mid to low 8 sec combos.
Let us know if there's anything else we can help you with.
Thanks!
Ransom
Ransom
Tn
Jonathan
In what way does primary diameter/length effect dohc vs ohv?
What are your thoughts on megaphone/reverse cone setups?
Thanks!
It will be more so an all out race setup, as its not my daily. If i can gain even the smallest amount hp/tq over the other and basically spend the same amount of money, ill take it. Really my only concern is fitment, i have read that with LTH brand the AC has to be removed.
I will definitely be in touch once i make up my mind.
GregO
Illinois
S550 GTPP
2V heads require a more refined header whereas 4V can afford to be a sloppy design and still make great power.
With open collector race headers I think there is merit to the collector “choke” that Calvin Elston uses on his headers but again the collector choke is more effective on 2V heads than 4V.
https://burnsstainless.com/blogs/articles-1/merge-collectors
You might want to spend some time on Don Terrell’s Speed Talk and search Calvin Elston. Calvin is a Wizard.
https://www.speed-talk.com/forum/index.php
If you want 2.00" primary 4:1 headers go for it. This isn't old school 2V non-VVT flow dynamics.
illtal
If it is all out race lose the AC. I believe the 2 in primaries might impact the AC lines, and they will be closer to the frame. You don't want them touching anything and causing a false knock.
That being said some brands 1-7/8 have these same problems.
