Dave2017GT
Just installed Eibach Pro Kit with HRE FF04 wheels. I thought i knew what i was doing but after install im not so sure. The wheels look amazing. The car is a 19 GT PP1. Drop was very minimal, 75" up front and .25" in the rear. Wheels are HRE FF04 staggered 10"/11". I paired them with MPS4S tires 275/35/20 and 295/35/20. 35mm offset up front and 55mm offset int the rear. I also installed Maximum Motorsports caster/camber plates then had it professionally aligned. Problem im having is a pretty decent amount of noises coming from the front and rear of the car. Popping sounds basically. Is this something that is normal and i shouldn't be too concerned with or is there a deeper underlying problem that has yet to rear its ugly face? Ive been doing some reading and some people have said that such a setup can cause issues with the drivetrain due to the rear end becoming misaligned which in turn causes the drive shaft problems after a few thousand miles. I honestly don't know much about suspension but it seemed easy enough but i think i might have overdid it. Anyones thoughts would be appreciated. The car looks amazing but im seriously considering putting it back to stock this weekend.
