Intake runner code
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
17 Mustang GT Whipple Gen 3.
Fired it up today after install.
Car ran good for a few minutes. Then threw a code for 'Intake runner control circuit misfire'.
This kit has no Fans. So anybody know what could be causing this code?
Thx.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Who is tuning you?
NGOT8R
Adrian
2019 Bullitt
Are you using lockouts? I was told a retune is necessary if lockouts are used?
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Do you have your IC pump triggered by the IMRCs or off of a switched 12v source?
NGOT8R
Adrian
2019 Bullitt
I thought the same thing until I read he has a whipple.
Don’t know who the OP”s tuner is, but I’ve read that Lund wants them locked out on supercharged cars.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Im sure they do. However whipple cars do not have IMRCs any more.
NGOT8R
Adrian
2019 Bullitt
I copy that, but doesn’t the tuner still have to turn off the signal to them, since they aren’t being used? I just figured as much because even though I’m still NA, I have locked mine out and Lund says they need to write new tunes for my car which will cost $150, but no data-logging would be needed. It doesn’t sound like it’s too in-depth, based on the price.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Yes for sure.
Cordero1
Kansas
Vic
2021 Mustang
What is the reason behind locking the IMRC's? Is it a must do when adding boost only? More hp?
NGOT8R
Adrian
2019 Bullitt
Sounds like it’s recommended on boosted cars. I don’t know if a car will make more power with them locked out. I only did mine because I wanted to declutter the back of the engine bay and eliminate the possibility of broken IMRC shafts, which apparently happens on occasion.
When I reached out to Lund about lockouts, here was John Nardi’s response:
“You will need all new tunes. No logging. Why are you locking them now? I keep seeing people do this and its creating more work for no reason at all . Did you break yours?”
Cordero1
Kansas
Vic
2021 Mustang
Ok I see. Well I'll just keep mine stock then. Thanks for your reply.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
PD Blower units replace the intake manifold and do not contain the IMRC system. If you're NA or using a centri or something it's a bit different, but even then there's no real reason to delete them. You just lose a bit of low end for no reason. I guess for less complexity it's nice to be rid of them though.
Cordero1
Kansas
Vic
2021 Mustang
So pretty much just to clean up the engine bay & avoid future mechanical failure from breaking said shafts. Ok thank you for adding that bit of info.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
Sorry I didn't answer or stay on this thread. I bailed on the tune after doing more research on the tuner and his lack of replying with any help. Also my NGauge became a paperweight during datalogging.
As far as who the tune came from, here's a hint:
Vastly Mounting Pain.
