Installing BMR camber bolts / torqueing bolts
Matti777
Edmonton
Matthew
2020 Mustang GT
Dumb question....it seems to be that after getting the desired camber I would need to remove the wheel, caliper and disc to properly torque the bolts. Is this what an alignment shop would actually do?
ps I had to do the opposite of what the BMR instructions said to get more positive camber and turn the big tab to the inside
bmrylnd5
@sugoispec
2017 Mustang GT/CS
Are you using 1 or 2 camber bolts per strut? If 1, which side did you put it on?
Matti777
Edmonton
Matthew
2020 Mustang GT
Just the top bolt per the instructions. The big tab was pointing to the wheel initially. Now it points inwards and I can get 1.5 deg neg camber.
bmrylnd5
@sugoispec
2017 Mustang GT/CS
yeah, I have the same setup, although IIRC I have the nut side facing the rear so it's easier to get access to (flip the bolt around so bolt head is towards front of car). My alignment shop had no issues aligning anything.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
You should be able to torque the camber bolt from underneath while it's on the alignment rack. If you can't then you might need to switch the bolt around for easier access to the nut.
Matti777
Edmonton
Matthew
2020 Mustang GT
I've got the camber dialed in and have been meaning to try torquing from under neath....maybe next weekend.
Dr. Norts
Ontario, Canada
Mark them with a paint marker once they're set then you can make sure they don't move easily by just doing a quick visual.
