DickR
Unless Ford has made a change recently (within the last 2 months) the replacement strut to spindle bolt is the exact splined 16 mm bolt used by the factory.Ford has their own procedure for camber adjustment (and probably their own bolts) just like they did for the S197.
It's a stronger and more reliable solution than any reduced-shank aftermarket bolts ever could be.
I cringe a little every time I read where people are going for the cheap camber correction solution without considering anything but price . . .
Norm
Note that the specified torque is 184 lb-ft. The idea of a smaller diameter bolt only torqued to 120 lb-ft as noted above makes me cringe also. The smaller diameter bolt used in the last of the S197's needed about 164 lb-ft per the manual and those needed to be checked periodically to prevent looseness which tended to result in broken spindle assemblies when used hard.
