Camber Bolts
Dat Boi Kumar
Rosharon,Tx
Chad
2015 Comp Orange Mustang GT
I went to get mine aligned today. Ive got the Sportlines and both front and back are to negative cambered. They adjusted the rear all the way it could go but still has -2.4. Anybody have sportlines and have there alignment print out please post it.
cbrtrx
tampa fl
2016 mustang gt
Doesn't sound like they did any camber adjustment in the rear, on sportlines I can pull the rear all the way out to -.8
Dat Boi Kumar
Rosharon,Tx
Chad
Thats what i thought so i made them put it back on the lift and lossen the camber bolt i went out there and i verifed that the camber bar could not go and more positive. Its has no more positive adjustment.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Do you know what the rear camber was when the car was still on its OE springs?
What was rear camber before they started adjusting it?
Are both sides the same (or at least fairly close)?
Norm
Dat Boi Kumar
Rosharon,Tx
Chad
Unfortunately no i wish i did know what the alignment was with tge stock springs. Driver rear is -2.1 passenger rear is -2.4 now i dont know what they were before they started adjusting it.
Dat Boi Kumar
Rosharon,Tx
Chad
Dat Boi Kumar
Rosharon,Tx
Chad
cbrtrx
tampa fl
2016 mustang gt
I've had both bolts in my hands, I believe the older ones are like 12 or 14mm and the new cars are 16mm. The smaller ones technically will fit but I would use the one made for it.
Dat Boi Kumar
Rosharon,Tx
Chad
The 94-04 camber bolts are 16mm
cbrtrx
tampa fl
2016 mustang gt
Ok, I was refering to the 11 to 14 cars. My car has sportlines and camber was within spec so I didnt have to install any bolts, I'm surprised yours would be -2 or more in the front.
Dat Boi Kumar
Rosharon,Tx
Chad
Thats what im thinking, maybe the shops alignment measurements are off. I spoke to Dave at Eibach and we discussed my situation and he was able to get -1.7 degrees on the rear of 3 mustangs they have done with sportlines so im gunna get another shop to give me some measurements. Can you PM me your alignment sheet?
cbrtrx
tampa fl
2016 mustang gt
Pulling my rear all the way out I was at -.8. I then adjusted it to -1.1 rear with proper toe and I was at -1.4 front with no camber bolts, which is around where I wanted it anyhow.
I'm not home now, when I get home if I find my sheet I'll send it to you.
Dat Boi Kumar
Rosharon,Tx
Chad
Preciate it
Tom
Earth
Daily Driver
Should the camber be the same as the back or a little less?
Just learning these setups. I would like to take mine to track when I get mine.
I think it would be wise for me, to take lessons before I track my car ( no autocross ) . Any help would be great. Thanks.
