IMRC LOCKOUT - WON'T START
Unleash-The-Beast
Flashback to 1965
Avon, IN
Mr. Ed
2015 Mustang GT Premium W. drop top
Did the IMRC lockout got the updated tune from Lund. Looks like everything's reconnected correctly. Loaded the tune but now it won't start.
It cranks and occasionally will catch a little bit for a second but it won't run.
Gas smell is very strong, don't see any leaks anywhere around the injectors or around the fuel rail.
(Did the clear out procedure for flooded engines, that didn't help. Let it sit for over an hour and came back and it fired again but just for a second.)
Hopefully I'm missing something simple and somebody will be able to get me a hint here.
JTM88
Tulsa, OK
Jason
'20 Mustang GT ESS G3/G4 PP1
What did your tuner say?
Pistol_91
Clearwater
2020 mustang GT
It won't hurt having a tune loaded that is meant for IMRCs enabled, when you have them locked out. It's literally just little flaps inside the manifold. It should still start. It may not run good, but it should start.
There's so many newbs on HPT forums trying to tune their cars with IMRCs locked out physically on their car, but never change it in the tune. So yes, flash it back to stock and see if it will start. If it does. Your Lund tune is broken.
Now if you changed injectors or something, then no don't try the stock tune.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
There is no reason to lock out CMCV/IMRC on a NA car. It's a solution looking for a problem. What they do is increase velocity and swirl in the intake ports and combustion chambers. This gives a torque boost at low RPM, also increases fuel economy if that is a concern.
On the manifold I'm currently tuning for I was going the wrong direction, I thought opening them earlier would improve low speed performance but testing showed they add tq up to 3300 RPM. Opening them below 3300 lost power. WOT and part throttle.
horsepower addiction
Arizona
Nate
s550
If all you did was lock out the IMRC’s you can load the last tune, nothing to worry about. Did you change anything else?
Unleash-The-Beast
Unleash-The-Beast
Flashback to 1965
Avon, IN
Mr. Ed
No sir, I did not change anything else. I will try the old tune and see if that changes anything.
Arizona
Nate
s550
I would try the tune also double check that you didn’t leave any ground wires disconnected at the back of the manifold
K4fxd
NKY
Re-flash your stock tune. Even if you have different injectors, the car will try to start or will start. This is the best test you can run. Dont try to drive it and it might start then stop, Which will repeat
Fords injector parameters are a bit confusing
