HVAC Condensate Line Location
Lurker_350
TX
2016 GT350 - Tech
Hi,
I'm doing some AC troubleshooting on my 2016 GT350 Tech I've owned since new. I can't find any leaks in the engine bay at fittings or the condenser and wanted to use a UV light on the AC drip line - hoping that if there is a significant evaporator leak that it might show up as a UV marker on the drip line.
I'm embarrassed to say that I cannot find the drip line, which is usually very easy to locate on a vehicle. Anyone have any pointers? I found a couple other folks that mentioned the AC dripping directly on the transmission - maybe the drip line ends right above the transmission? I know @honeybadger and @Muligan have had their transmissions out - hoping they might be able to help.
On a related note, the OEM workshop manual says its only 37 distinct steps to get the dash out to replace the evaporator assembly, so I've got that going for me :cwl:
Thanks all!
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Hi,
Thanks all!
I don't recall ever seeing a drain. I looked through the service manual and didn't see a reference to it either.
That said, an AC failure is almost always the coil inside the car that requires removing the entire dash. My car had that and a few of my friends with the earlier cars (15-17) have to get theirs replaced as well.
Lurker_350
TX
2016 GT350 - Tech
V8_MOTOR
Nottingham, UK
MY17 S550 Mustang GT (EURO)
Just to help you. I used my endoscope camera to get a look in there. Nice and dry and not blocked. Next plan is to decontaminate this area for me.
Lurker_350
TX
2016 GT350 - Tech
Thanks for posting that!! I forgot to respond back to this thread since I ended up not having to pull the climate control housing/evaporator out. Never ended up confirming or denying the drain location.
I'm sure your post will help others troubleshooting their A/C!
