02gtnh
Where did I bash Ford?:shrug: You gave us this formula link and it seems to work well with the manual cars, but not autos. Autos are know to be faster, but heavier then manual, so how can the numbers be the same? The SS auto got a 12.3 at 116mph, so by your link it should have 482hp. The SS is SAE certified at 458hp, so that 24hp more. The manual SS got a 12.4 at 114 mph so by the link should have 448hp or 10hp less then SAE. The GT manual at 13.0 at 110 mph so link shows it should have 417hp or 18hp less. Yet the GT auto also got 13.0 but at 113mph, so link shows it should have 456hp, or 21hp more. So you can see there are quite a bit of difference between the manuals and autos of both. As far as the ATS V time, it isn't feasible in my mind and has not been duplicated yet. So either there instruments were off, or it was boosted. But since it has not been duplicated, I don't put much faith in it.:cheers:The only things that can throw off the formula are large temperature changes, windy conditions, and low or high frictional losses in the driveline. There is always a mph or 2 diffrence between autos and manuals due to friction losses, in the past being higher in autos. The geartrain of an auto can be heavy, and has friction losses like the hydraulic pump that a manual does not have. Modern autos are getting much better and may in some cases exceed, but its hard to know without making changes to even out the inconsistency. Like gearing each car for max rpm in the 1/4, slicks to allow the manual to uses its flywheel inertia, and no lift shifting the manual. A good example is NHRA stock and super stock class records. When I first started racing, auto's were about .2 behind the sticks, class to class, now 38 years later they are ahead.
Now with all that being said, we should also be told what the density altitude and the wind speed and the direction is. Also, we should be using weights that are measured and not manufacturer reported. I don't know what all those are, to get a more accurate result. Remember I said these are flywheel estimations, that means a standard loss percentage is being applied equally against all set-ups in the formula, and that is also a small inconsistency. It also assumes 0 wind.
After all that, you should be asking yourself, why is the Camaro so far off compared to the others? Is it all the A8's phenomenally low fictional efficiency, or has it been tweeked. Have different A8's run the same times in different hands in similar conditions. Do we see the same difference in the corvette between trans and exteme HP spreads. I believe its far too early to tell.
I am a Ford man, I give the benefit of the doubt to Ford, many here apparently to the chevy, but last I checked, this is mustang6g, and I don't care for a lot of chevy guys coming over here to defend in my eyes what I feel is shady practices by GM. Did you do the math on the 122 caddy? Probably not, you are here to bash Fords and give chevy a pass..
