HOW TO: Swap PP gauges into standard model
Bill88stang
2016 deep impact blue premium gt 6 speed manual
How would these instructions sorter if I was just installing the one from a gt pp car that had the oil pressure and vac only?
zackmd1
zackmd1
Zack
If swapping a new center gauge cluster into a factory PP vehicle, none of the wiring is needed. The cluster swap will be plug and play.
Bill88stang
Mine is just the premium, the instructions were to hook up the oil pressure and temp guage, wondering what I'd have to tap into for the vacuum guage thats all
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Nothing different. All the data the gauge displays comes from the CAN-BUS network. The differences are all internal to the gauge set.
Aurum
Los Angeles
Is it impossible to get the PP gauges to work with the standard model *and* a premium non-PP car?
Bill88stang
Ok so I would still just tap into the same connectors as listed on the first page?
zackmd1
zackmd1
Zack
Correct. The OP applies to both base and premium non-PP vehicles. The oil pressure gauge is not functional at this time.
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
For the same reason, a GT gauges set (oil pressure and VAC) should work without issue in an EcoBoost, right? I bought a PP dash trim from ebay and it has the GT gauges included.
Since I don't want to pay >200$ for a brand new EB gauges set, I'd like to use this while waiting for a good deal :)
Bill88stang
So our saying doing this the oil presssure gauge still won't work?
zackmd1
zackmd1
Zack
Correct. We have been able to activate the oil pressure gauge through a tune but the low oil pressure light comes on since the PCM connector pinout is different between non-PP and PP vehicles. You could attempt to correct the pinout issue but that is more in depth then most want to go.
Bill88stang
Damn that sucks I thought from what I had read it was all good to go
Aurum
Los Angeles
I'm fascinated that an aftermarket group hasn't figured out a solution to this and mass marketed it to us.
zackmd1
zackmd1
Zack
Same here. Must not be financially feasible, or someone would have done it already.
The problem lies in the fact that not only would they need to create a gauge cluster, but they would also need to create a dash trim panel. Much cheaper and simpler to sell a gauge adapter for one of the ac vents.
Aurum
Los Angeles
That assumes making a complete plug and play solution. You could simply manufacture the wiring harness required, charge a noble premium for it and the R&D, and then force vanity users like us to source the trim and gauge panel.
I'd probably prefer that actually so I could source the GT350 trim.
