How to determine bad cat on FI
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
Developed a slight rattle under the car recently. Put it on a lift and we inspected everything under carriage from the front of the engine to the tail pipes and found nothing loose or touching.
We tapped the LH side cat and it was solid. Tapped the RH side cat and it sounded different, like something was not quite right compared to the LH side.
Might be my imagination but it feels down on power as well. No codes. Drives smooth as ususal.
How can I tell if a cat is going out? Any way to test?
engineermike
La
2018 GTPP A10
1. Remove cat and inspect from inlet and outlet.
Or
2. Put borescope in o2 sensor hole and inspect upstream element.
Or
3. Measure exhaust pressure at full load.
Or
4. Log rear o2 sensor voltage and plot over time. A bad cat will show frequent high/low switching.
Jackson1320
California
Jaxson
2015 mustang gt
If you blow the cat out you will get a code. If you melt it then you are going to feel like it is down on power. It will get worse and worse and you will feel it more with rpm
schmeky
schmeky
David
Thinking about getting a take off 2018 - 2020 exhaust manifold set, removing the cat interior and welding in a SS tube of the appropriate diameter to make a straight through (not originally my idea) shot for the exhaust gases.
Jackson1320
California
Jaxson
2015 mustang gt
Keep the cats and just clear everything out of them. That way if anyone looks it will look stock
schmeky
schmeky
David
Jackson1320,
That's exactly my plan. Keep the "canister", less guts, and simply weld in the appropriate tube.
mangosmoothie
Flagstaff
Casey
2019 Boolet
Idk if there’s data on mustangs but on mazdaspeeds gutting the cat caused a lot of turbulence. The best fix was to weld a straight pipe through the cat area if you wanted to keep it looking stock.
schmeky
schmeky
David
mangosmoothie,
That's exactly what I said.
