How to verify that a bap is bad
xxchieferxx
lol@ mpg
Louisville Ky
Charles
2015 Mustang GT
I have a vmp bap with pnp harness. How would i go about verifying that it is not bad? I tried searching qnd couldnt find anything. Im on the lund ngauge.
Tommy V
Brookly park Md
Tommy
Whatever wire u is feeding voltage out of your bap should be putting.out 18 volts if on the 18 volt setting.U can also check the power wire at the fuel pump connector to make sure it has boosted voltage.Make sure your padal is to the floor when checking if it works of the pps.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I've in the past verified it was raising voltage when in boost by using a multi meter. Just tap the power wire from the BAP to fuel pump and extend leads so you can see it raise while on boost when driving.
uscavman
Killeen, TX
Al
2016 Mustang GT Premium
I would create a new ground terminal if you haven't already. I had to replace a short block because my BAP wasn't putting out the full 18v.
