Fly2High
- Sep 9, 2019
- Long Island
- Frank
- 2019 Mustang GT PP2
All,
After purchasing a set of aftermarket wheels, I received a bit of an education from a person at Gorilla. From my understanding, the S550 Mustang GT takes a M14 x 1.5 bulge conical lug nut. It uses a 21mm socket.
I went on to ask several questions asking for a variety of lugs nuts they sell that might work in my application. The aftermarket wheels have a 32mm lug pocket which makes it challenging to use the OEM lug nut or any OEM replacement since they tend to have a 21mm socket and are about 30mm in diameter.
I went on to ask which ones would work for both OEMa nd the aftermarket and they stated that only the OEM style (30mm dia) lug nut could be used.
I decided to ask some questions and it appears that just because a lug nut is a bulge cone and is M14 x1.5 with enough threads and height to fit the studs is enough.
I also found an interesting discussion on a Corvette thread ( https://www.corvetteforum.com/forum...lugnut-question-bulge-conical-vs-conical.html) about the differences between the recommended use of either bulge or regular cone for them. They are able to use either because , it appears, that as long as the mating cone fully covers the wheel seat, it will be satisfactory.
What bothers me a bit is when I read about recommended lug nuts for OEM that, according to users, do not. At CJ Pony Parts, they recommend a 'small diameter' (not a spline so it is really not a small dia. according to Gorilla) lug nut (https://www.cjponyparts.com/gorilla-lug-nut-kit-small-diameter-black-2015-2020/p/WHLLN17/) that has comments indicating they do not cover the OEM seat. They indicate that , when used with a black set of wheels, some of the unpainted seat is shown. These are Gorilla 41148BC. I would assume this is also true for the other small diameter Gorilla nuts they sell (https://www.cjponyparts.com/gorilla-lug-nut-kit-small-diameter-chrome-2015-2020/p/WHLLN16/) or Gorilla 41148HT.
I do not have these small diameter lug nuts to measure. If you do, could I ask you to post the diameter of the lug nut?
Trying to take measurements off the screen suggests that the OEM replacement is about 30.8 mm in diameter which is close to my actual measurement of 30 mm on the Stock part. When I measured the 41148 image, I get a diameter of 23.4 mm. This would explain why a chrome rim on black wheels is seen. You will have 3.7 mm ring around the nut.
If you have the CJ Pony parts small diameter lug nut, could I ask for a close up of the lug nut installed with a attempt to shoot a photo of the lug seat with it?
I am sure there is also some undocumented specification for the load rating for the lug nut as well which we never see. I always wonder how Amazon or any site truly determines which lug nuts will fit and which do not.
My thinking is that even if the manufacturer stated it is a M14x1.5, bulge cone seat with around 1.4 or greater length, I have a feeling that still doesn't guarantee fitment. My feeling is that the diameter of the wheel's seat must also be taken into consideration and as long as the seat is filled, it will work. Having the seat exposed/not filled by the lug nut, could be asking for trouble.
Can anyone shed some light on this? I know most will just go by recommendation hoping the manufacturer/dealer has worked out the details.
If the depth or diameter of the seat is needed to determine proper fitment, why is it most dealers do not have this information and most if not all lug nut manufacturers do not post it?
Any ideas or thoughts are helpful.
Thank you.
Frank
Thank you.
Frank
