Where did you get the equations from I feel like something might be slightly offHere are my calculations. Am I doing anything wrong?
I didn’t get the equations from anywhere. Just common sense. I know the calculations I did are correct. Maybe I am missing a factor that I didn’t account for.Where did you get the equations from I feel like something might be slightly off
379 ft-lb torque at the wheels would be impossible since the engine torque is 350 and there’s expected up to 25% loss through transmission.https://x-engineer.org/automotive-e...hicle-dynamics/calculate-wheel-torque-engine/
Equation 12 gave me 379 ft-lbs I think you’re missing a multiplication by 2 somewhere in the there
Just because a manufacturer says 350 doesn’t mean it is. Sometimes cars are underrated by a lot and sometimes overrated. I’m no expert on the subject as I’m an aerospace engineer and haven’t worked with torque and ratios in a while so I had to look the equation up. Best way would be to look at a dyno and verify. I looked up a dyno sheet for a 19 EcoBoost and it dynoed at 288 and 380 x 0.25 = 285 so it seems spot on.I didn’t get the equations from anywhere. Just common sense. I know the calculations I did are correct. Maybe I am missing a factor that I didn’t account for.
From my dash.Where did you get the 6.570 m/s figure?
Thx for the reply. There are a lot of good points here.I’m a little lost as to where the input came from, namely the acceleration.
Assuming the acceleration came from the dash accelerometer:
6.57/9.81 = 0.67 G
mass of car * accel = thrust
4200 lb * 0.67 = 2800 lb of thrust
thrust * tire radius = axle torque
2800 * 14/12 = 3300 ftlb
3300 / 3.15 / 4.69 = 223 ftlb
The 10r80 only absorbs about 10%, so
223 * 1.1 = 245 ftlb
This is still low but I think a few things will account for it:
Traction - Depending on tire, it might not be holding max torque. I know my PS4S will only hold about 0.75 G on most surfaces. A lesser tire won’t hold as much.
Torque limiters - The cal has dozens of torque limiters. I don’t know that the factory cal will even allow max torque to be produced in 1st gear.
Drivetrain inertia - In low gears, a lot of power is absorbed by accelerating the rotating parts of the engine and transmission. This is the difference between “brake” and “inertial” power. This is also why cars make more rwhp on dynojet-style inertial chassis dynamometers in higher gears.
I would reset the accelerometer and try again in a higher gear like 6th and be sure to start at a low enough rpm to capture the torque peak.
