mohadnuj111
Here’s a 2020 builtt with 4.88 gears
Is it Still longer than 15-17 3.73 gears?
Yes......It......does.4.88s seem pretty reasonable actually. It makes the 3.55s seem ridiculous!
The only way to make 4.09 gears play nice with '19 and up cars (rev matching downshifts, gear position sensor in the MT82) is to purchase this from Ford Performance:Has ford got a plug and play tune for the 4.09 final drive ratio?
Will the stock tune work with 4.09 gears on 2018 cars which don't have rev match but came with 3.55 gears from factory ?The only way to make 4.09 gears play nice with '19 and up cars (rev matching downshifts, gear position sensor in the MT82) is to purchase this from Ford Performance:
https://performanceparts.ford.com/part/M-9603-M8B
This allows you to change the Ford Performance tune to 4.09 gears.
The issues with 4.09 gears (really anything lower than 3.73 gears - the lowest option from the factory) seem to be limited to '19 and up cars when it comes to the MT82 equipped cars. '19 and up got rev-matching and the transmission also got a gear position sensor.
You CAN get your factory tune modified to play nice with the 4.09 gears. You don't even have to change anything in the the tune but the settings involving 4.09 gears. Any good tuner familiar with the newer S550 should be able to do this pretty easily.
Downside - you'll have to purchase a device to upload the tune to your car, and either pay for a tune or if you have local tuner, they will adjust JUST the settings needed for gear ratio usually much cheaper than a full tune.
Or you can buy the HP Tuners software / hardware + the credits you need to modify your tune (you need 4 credits for the 18-21 Mustang)
https://www.summitracing.com/parts/hpt-m02-000-04
A tick under $500 and you could make the changes you need to run 4.09 gears. The benefit to doing this way - if in the future you decide to add modifications or get tuned (E85 etc) you only have to purchase the tune file from the tuner you choose - you can use the HPTuners device to upload the tune to your car.
There are few people here with '18s who've done the swap with no issue from my understanding.Will the stock tune work with 4.09 gears on 2018 cars which don't have rev match but came with 3.55 gears from factory ?
just the reply i needed, thanks! too bad the car is a bag of shit and always broken, if not i would've been done this.Your tune has to be adjusted. It's a max gear ratio setting inside the tune.
2019 PP1 3.73 gears MT82:
7000RPM in 4th gear is 154mph with a 275/40/19 tire
With 4.09 gears:
140 mph
What were the rpms at 70 and 75 mph if you don't mind sir?I remembered to check on my last drive. 80mph comes up at 2500rpm with 4.09s, 6spd and 325/30/19s.
Im sure someone has done the math on this so it’s probably not news but I figured I would share anyway.
The weather is looking crappy enough here today that I took the hatchback and left the Mustang at home so I can't just take a look this time...So you're going to make me dust off my long forgotten algebra "skills?"What were the rpms at 70 and 75 mph if you don't mind sir?
Instant wheel spin...I wanna go twin-turbo. I got an mt84 d4 and would 55mm hellion twin-turbo (tuned) give me instant power similar to a Whipple on low rpm.
