Superspirit
4.09s are awesome with the mt82d4
How often does that ford performance parts package go on sale I wonder?The only way to make 4.09 gears play nice with '19 and up cars (rev matching downshifts, gear position sensor in the MT82) is to purchase this from Ford Performance:
https://performanceparts.ford.com/part/M-9603-M8B
This allows you to change the Ford Performance tune to 4.09 gears.
The issues with 4.09 gears (really anything lower than 3.73 gears - the lowest option from the factory) seem to be limited to '19 and up cars when it comes to the MT82 equipped cars. '19 and up got rev-matching and the transmission also got a gear position sensor.
You CAN get your factory tune modified to play nice with the 4.09 gears. You don't even have to change anything in the the tune but the settings involving 4.09 gears. Any good tuner familiar with the newer S550 should be able to do this pretty easily.
Downside - you'll have to purchase a device to upload the tune to your car, and either pay for a tune or if you have local tuner, they will adjust JUST the settings needed for gear ratio usually much cheaper than a full tune.
Or you can buy the HP Tuners software / hardware + the credits you need to modify your tune (you need 4 credits for the 18-21 Mustang)
https://www.summitracing.com/parts/hpt-m02-000-04
A tick under $500 and you could make the changes you need to run 4.09 gears. The benefit to doing this way - if in the future you decide to add modifications or get tuned (E85 etc) you only have to purchase the tune file from the tuner you choose - you can use the HPTuners device to upload the tune to your car.
Message Benny at levitown Ford for a group but discount code. Cuz it doesn't go on saleHow often does that ford performance parts package go on sale I wonder?
I own a ‘16 GT PP1 and a ‘22 GT PP1. Both came from the factory with 3.73 Torsen diffs.The ONLY way I could see a 4.09 being useful is the '350
lol. umm...4 years later?I own a ‘16 GT PP1 and a ‘22 GT PP1. Both came from the factory with 3.73 Torsen diffs.
Both cars are blown with Roush blowers.
When I first had the ‘22 blown, the ‘16 was still quicker.
I had the FP 4.09 diff gear installed in the ‘22 and it was, for all intents and purposes, identical to the ‘16.
The 4.09 is useful for more than just the GT350.
NFN, but in my experience 99% of dealers can do little more than plug and play factory parts and maintenance. You need a good custom speed shop with experience in modern Mustangs, or a highly capable indy shop.Update....I've called 3 Ford dealers over the past few weeks asking for an installation cost of the 4.09's. All of them said they'd check and let me know but none called back. I wonder if it's just bad luck or if they don't want to do this for some reason?
Also, did some calculations... 7000 rpm in my 3.73 car in 1st is 47 mph, with 4.09's it would be 43 mph. In 2nd it's 73 mph vs 66 mph, and in 3rd it's 108 mph vs 98 mph. So in terms of 0-60, you wouldn't have to add an extra shift if you went to 4.09's, but you might in the 1/4 mile. Also, at peak 420 lb-ft of torque at 4600 rpm, the force applied to each tire patch would increase from about 2200 lbs to 2400 lbs, which would be the equivalent of increasing the peak torque from 420 to about 460. So the 4.09's seem like a pretty good mod if it's reasonably priced.
LOL I posted that 4 years ago... ended up doing it the following July, was my favorite mod on the 2018 GT.NFN, but in my experience 99% of dealers can do little more than plug and play factory parts and maintenance. You need a good custom speed shop with experience in modern Mustangs, or a highly capable indy shop.
Not sure when Ford changed the ratios in the Getrag, but my 2020 Bullitt with 3.73 gears is much longer geared than I expected. They messed with the ratios and 4th is a 1:1, so 5th & 6th are 'overdrives'. Fine for me as my dig and track days are over, but if I was racing, I'd want to go with a higher rear ratio. 4.09 seems to be common and easy bolt in.
Yeah, 4 years later...what's your point? Lol.lol. umm...4 years later?
