High Beams + Fog Lights?
Lost
Upsate NY
2016 GT Premium 6 speed blackout /3.55
Anyone do this mod yet?
Or if not, can anyone post the relevant schematics so I can quickly figure out where to wire a diode to energize the relay? Or maybe it is not an easy mod if the fogs are driven with a body computer?
I like the wide spread of light the fogs generate close in. Silly maybe, but that's just me.
Lost
Lost
Upsate NY
Anyone have access to schematic for the LED fogs?
Blue Horse
Mustang GT
Go to your Ford Dealership Parts Dept and purchase the service manual for your Mustang,that will have ALL the info you will ever need.
bee bop
Temple, GA
2002 GT Vert, 2016 GT Vert
All Lighting is controlled by the Smart junction Box. You cannot just add additional wiring and make it work. Also running fogs with the high beams is illegal.
Lost
Lost
Upsate NY
Thanks.
I still think it possible, and far as legality, they are pretty pusillanimous fog lights, not too worried. Certainly nothing compared to the wankers running HID's in reflector capsules.
wildcatgoal
@sirboom_photography
TBD
Just use a relay triggered by the high beams that gives power to the fogs when the high beams are on. Not sure if this is possible with the wiring but done it a zillion times.
Lost
Lost
Upsate NY
Right, the question is, does back feeding the SJB cause any issues?
wildcatgoal
TBD
Diode it up, don't have to worry about that then. You know what you're doing.
Lost
Lost
Upsate NY
I do. (more or less)
There would be a .7 volt drop across the diode though, possibly decreasing the brightness of the fogs.
wildcatgoal
TBD
Fogs are LED. Doubtful they use enough power for that to make a difference.
