Help removing A-pillar on Vert
300mag
Atlanta
17 Ecoboost Prem Vert
Anyone help with changing Tweeters on Convertible. I know the A-pillar pulls out but it looks like the sun visor needs to come out first before pulling out A-pillar. trying to figure out how the sun visor comes off , looks like there is a plastic plate that covers the screws but the plate wasn't popping off too easy. just wanted to see the easiest way before i do any damage. Thanks.
300mag
Atlanta
okay figured it out, the small part of the cover pops off exposing a dash type clip that holds the sun visor in. You need to remove this clip which will then allow you to tilt the sun visor out. The clip can be tricky because it has inner prongs that need to be compressed as well but accomplished using small jeweler type screwdrivers on both sides of the clip. Once I figured it out the other side came off pretty easy. once the sun visors were off then the A-pillar pulled off.
gammer2019
Olathe Kansas
Christopher
2017 Mustang GT Convertible
Exterior trim is what I need, not the internal.
WILDB
Australia
Will
2017 GT convertible Oxford White
You need to remove the internal trim to gain access to the hardware for the external.
