Help please door will not open
activeuk
westmidlands
mustang
Hi not used the car for a week and the battery as gone flat tryd to use the key with the remote and the door will not open any help
Twin Turbo
Super Moderator
Moderator
England
Paul
Mustang '05 GT
Use the blade key hidden in your key fob :)
[ame]
Just beware.....if your battery is dead, your windows will not drop, so don't slam your door!
Actual
Bracknell, UK
Mark
2015 Mustang 5.0 V8 GT Auto Fastback Black
This has happened to me http://www.mustang6g.com/forums/showthread.php?t=86513
Have you completely removed the little plastic cover from the drivers door handle?
Retrieve your emergency key either the single supplied with the car or carefully break open a key fob and there is a key inside.
The trailing end of the drivers door handle is a little plastic cover.
Push in the emergency key from underneath or use a screwdriver to release and slide off the plastic cover.
Now a conventional key hole will be revealed. Insert emergency key and turn.
