Help getting traction after sc install pls
whipstang
UK
Kev
Hay guys
Done a lot of work to my 2016 GT all of it bought from people on this forum :cheers:
Still got one or two things to do like a new vented hood and rear wing.
But what i after at the moment is some help getting the power to the pavement.
It should be putting out pretty close to 720 whp
The mpss just can not handle that level of power at all,she just spins up in the first 4 gears no mater if i am progressive with the throttle or not.
Most of my build info is below the car is a daily driver, want to hit some race tracks with it too.
So 95% on the road 5% track.
I have tried lowering the tyre pressure's but no deference.
So any hints help or advise on getting traction would be very much appreciated :shrug:
Thanks guys :D
Build info fitted by FCM Motorsport
Whipple Stage 2 SC Kit
Dual 11" Fan Kit to Heat Exchanger
10 Rib Kit Upgrade
JMS Fuel Pump Voltage Booster
MMR Crank Sprocket
MMR Oil Pump Gears
McLeod RXT Clutch
Mcleod Steel Flywheel
Driveshaft Shop Carbon Fiber Drive Shaft
Driveshaft Shop 2015 Mustang 1400HP Axle (Right)
Driveshaft Shop 2015 Mustang 1400HP Axle (Left)
BMR Cradle Bushing Lockout Kit
BMR Rear Lower Control Arm Spherical Bushing Kit
BMR Sway Bar End Link Kit - Set of 4
BMR Double Adjustable Rear Toe Rods
BMR Aluminum Vertical Links (Spherical Bushings)
BMR Adjustable Front and Rear Sway Bar Kit
BMR Front Subframe Chassis Brace
FRPP Toe Knuckle Bearings
X-Force 2015 LONG-TUBE HEADER HEADER SYSTEM WITH DUAL VAREX 3" EXHAUST SYSTEM
MRR M350 Wheel's 19x10 and 19x11 with Mpss 275x35 100Y 325x30 105Y
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
You'll have to use a drag type tire. Mickey Thompson or similar. MPSS are really hard tires, you need a softer tire.
HoustonGT
Danville, CA
2020 GT PP2
Street drag radial for traction, won't last long but they hook up ok. Or sacrifice some traction and go with a harder MPSS/Nitto/etc for longer life. I don't think a soft street drag radial exists that lasts more than maybe 4,000'ish miles if you drive very aggressive. At least based on my experience...
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
NT555r holds just fine and will last 10k. I'm at 5k on mine and they still have good life left in them. It's DR or bust!!! Since you have 19's you can go with the Pirelli Trofeo R but they are ~$800 or more; there is a sale on them at discount though. My buddy with 890 whp twin turbo says they are hold fine and amazing tires. But the wear is the same as DR's.
beefcake
Bethel
2018 Ford Mustang
stickey tires and viking shocks are your first 2 things you will need.
hit us up with any questions or anything you need
thanks
stang17
Wilkes Barre, PA
2017 GT Premium PP
IF you are on the stock whipple tune...use flight control to take 25% out of 1st and 2nd, take 15% out of third and you'll be fine. This is what I do with my stock pzeros and 3.73 gears for street use and seems to work fine.
whipstang
UK
Kev
Thanks for the replies guys
looks like i will be trying some new rubber :-)
HoustonGT
Danville, CA
2020 GT PP2
I wish i could get 10k on a set of 555R's...
sigintel
Ray
2018 GT
MPSS compound needs some heat before it performs and even then it cant touch drag tires. What pressures are you running?
Have you tried 25-28 cold rear?
Dont freak out how squirmy they are cold, just get some heat in them before you go apeshit.
Also, very important, what is your rear camber and toe?
As you have a stiff sidewall and very little of it, your contact patch can get distorted w excess load bias/camber towards the inboard edges. Try backing your rear camber off a hair and go 0.7 to 1 range to start.
Under rear weight shift and squat the camber gain may make the situation even worse. (As weight in rear goes up, camber may increase even more).If you have someone do your rear alignment for you, ask if after they get the first reading, place 160# of sand bag in rear of trunk. re read. Then another 160#. reread. (or just have beer drinkn friends sit on rear w trunk open). You can have the camber set at 2.0 max at 500# rear trunk load and then unload and see where it is.
Go 0 rear toe to start. There may be a *slight* improvement off line to have a hair of toe out so as the suspension loads up it is 0 toe dynamically. You can add a 800# tension cable from rear spindle to frame on both sides to set toe under load and then unload to see what you get.
Chalk or white spray paint across rear tire to see the wear.
Obviously, taller and more compliant/softer sidewall of a drag tire will square the contact patch way better and makes the above less an issue.
MPSS 305 19 square DD
NT01 305 18 square track
NT555R 305 35 18 rear only hoonage set ( these are mmeh, would try NT05R, MT or Hoosier next)
whipstang
UK
Kev
Yeah have tried 24 ,26 28 psi that i am running at the moment no differance really , the whipple is just to brutal for them
Im even running at -25% and -15% power in first and 2nd to try and help grip.
I think i better wait till after the winter (im in the uk) and then put some track tires on it like the PILOT SPORT CUP+ / N-SPEC
I dont mind changing tyres one a year to have grip :-)
thanks for your advise :cheers:
Barrel
Hoonigan
Cars and Trucks
NT05R - superb tire. Any of these tires will struggle in cool weather, though, so best of luck in the UK. I run the MPSS on the street since rain and cold weather doesn't upset them too bad.
BrianGT2015
Iowa
Brian
2015 Mustang GT PP, 2015 Mustang Eco Convertible
This is why as much as I would love to daily drive my car when she gets done I don't plan on it. Bubba you might wanna get a new set of rims and tires. Have a set for daily use and a set for weekends and track days.
BBW P1X
Arizona
15 Mustang GT
I run ET Street R's on the rear and hook pretty good once warmed up and warming them up isnt really tough, i run 305 45 17's, i used to have nitto 555 g2's, on a 19 inch rim and i wouldn't hook, i'd spin in every gear, the ET street R's may have some spin but its a straight line spin versus, being all over the place.
