Hello and help with active exhaust
jwt
Alberta
2019 Ford Mustang Bullitt
Hi
Just bought a new to me Bullitt K4163.
Probably having a senior moment but I cannot figure out how to change the exhaust mode.
I hit the pony button
VudC5vdXRsb29rLmxpdmUubmV0QDg0ZGY5ZTdmLWU5ZjYtNDBhZi1iNDM1LWFhYWFhYWFhYWFhYSIsImhhcHAiOiJvd2EifQ.jpg
Exhaust Mode
VudC5vdXRsb29rLmxpdmUubmV0QDg0ZGY5ZTdmLWU5ZjYtNDBhZi1iNDM1LWFhYWFhYWFhYWFhYSIsImhhcHAiOiJvd2E...webp
And all I get is quiet start
Which is not set to on
and even if it was pics were taken after 8am
Am I missing something incredibly stupid?
All pics were taken with engine running in neutral
Thanks and hello :)
Louk
America
Lou
F90 M5, 2022 TRX
In the third picture where it says “quiet start” hit your up arrow. Your just at the bottom of the page need to scroll up
ivantwilliams
Georgia, USA
2018 Mustang GT Premium with Performance Package
Based on Louk's response, were you able to find it?
jwt
jwt
Alberta
Well, don't I feel stupid.
I was checking admin keys, trying different modes, mymode lol.
might as well go 2 for 2, apart from a scheduled quiet start if i turn on ignition, select quiet mode, then start, the car reverts back to normal exhaust and I can then select quiet but by then the damage is done and neighbours are awake. Can you force the car to start in quiet mode without having to schedule a time?
lonefire
lone
2019 Mustang GT
Can I hijack your thread?
I too need help with the active exhaust.
I have the non digital dash and the 400A package so I don't have a pony button on my steering wheel. I assume the exhaust mode is changed when I changed the drive mode from normal to track in the center console right?
Louk
America
Lou
F90 M5, 2022 TRX
Yes you can “force” it to simply by setting quiet start time with car not on but accessories on for later than the current time. Then turn the car off open the door let it shut down. Then turn car on and it should start as quiet
I’ve done that a few times.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
You can also change it under "Settings", "Exhaust Mode" in the menus. This will override any setting established by drive mode selection.
ivantwilliams
Georgia, USA
In the Quiet mode scheduled timed setting, can you not set it to something like
start between 00:00 to 23:59, or something like that?
Louk
America
Lou
F90 M5, 2022 TRX
You could also do that set it to be quiet mode 24 hours never tried it. But I’m sure you could do 23 hours and just make the hour one you are sure you will never drive it or mid afternoon so it’s not a big deal.
jwt
jwt
Alberta
Yep crossed my mind, was just checking I wasn't being silly and missing an easy push this to start in quiet mode on an ad-hoc basis as required.
All good
Thanks
ivantwilliams
Georgia, USA
Also, if you then set Quiet to 24 hours, you can then set My Mode to what you want, too. Once you're out of your subdivision, two clicks on the toggles, and you get your mode...
Elp_jc
None
You can adjust the exhaust mode BEFORE starting the car, by turning the ignition on (no clutch or brake pedal depressed), selecting quiet, then starting the engine. Or if you have quiet exhaust on your 'MyMode', select that mode before firing up the engine. But the quiet mode setting is nicer, since it always kick in without having to do anything. I need to set mine from 9pm to 9am, in case I ever need to drive, and forget to quiet it down.
