It is quite a different comparison, there are too many variables to compare the 15-17' and 18'Probably nothing. Gas velocity at that point downstream I bet isn't flowing fast enough to make that big of a difference closed or open in stock form.
Comparing the results of the GT350 aftermarket systems to the new stock '18 system is total apples to oranges to kumquat and squashed banana. Air requirements in and out are different and will have different restrictions based on heads, manifolds, cats, and resonators.
I see lots of people discredit the significance of cat back exhaust systems for performance gains when there clearly is a gain of 7 wheel hp for the 15-17.
You do realize that the GT350 Borla Catback costs TWO THOUSAND dollars, right? It's the worst power per dollar ratio in any point of the powertrain. The biggest benefit to that catback is actually weight reduction. Do you really think you're going to feel 7 HP? That is within the variance of error on the same dyno on the same day, or 1.5% power.I see lots of people discredit the significance of cat back exhaust systems for performance gains when there clearly is a gain of 7 wheel hp for the 15-17.
