Header installation
Ericlp
Wisconsin
Eric
2017 Mustang GT
Hi first post on this forum, hopefully I'm putting it in the right spot. I want to do headers on my 2017 mustang gt. I already have a Corsa sport catback exhaust, was thinking of going with looks long tubes 1 7/8. My question is 1. Should I go catted or catless and 2. Will the looks longtubes bolt straight up to the Corsa exhaust? No cutting or welding needed? If I pay a shop to do it I want to make sure I have every single thing I need before handing it over to them.
SlowyoteJay
Georgia
Jay
2019 Mustang GT Premium Non-PP
I have a 19 GT with corsa xtreme catback and kooks 1 7/8 long tubes with the hi flow cats. They do connect perfectly fine. You do have to use the factory clamp that connects the oem headers to the catback. I did it on a jack and jack stands, definitely would not recommend but a shop should have no issues. In regards to cat vs catless, keep in mind tuners can’t trick the system in to thinking you have cats so if your state/ county does emissions, that’s one thing to keep in mind. I personally wouldn’t go catless unless I’m building a full on track car
Ericlp
Wisconsin
Eric
2017 Mustang GT
Even if they delete the engine light in the tune? Where I live all the do is check to see if the CEL is on.
SlowyoteJay
Georgia
Jay
If all they do is check the engine light, you should be good. Where I live in GA, they have to hook up a device that scans the obd readiness codes. I had to use an o2 sensor spacer to basically trick the system into thinking the cats were working the way they were designed to.
Ericlp
Wisconsin
Eric
2017 Mustang GT
Yea I think they will be good for that. If not I have other ways to get past it. And I plan on doing some sort of forced induction down the road so I don't particularly wants cats for that reason.
Zrussian13
Phoenix
Most big name Tuners won't turn the cel off anymore.
Mspider
Michigan
2022 GT
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
Yeah, I don't know if any tuners would still do this...
Standard High flow cats may not survive (or even fix the CEL anyway) but i can say the Gen2 (400 cell) GESI G-Sport cats DO work well and no CEL. Their Gen2 UHO cats are supposedly good for up to 850HP (PER CAT) so I would think they'd be good for boosted applications as well, but you can always reach out to them or try to find someone who's boosted with them. I got mine previously from MAK Performance - you could probably reach out to them as well to see if they have any experience on a boosted 5.0 with them.
https://gsportbygesi.com/high-performance-catalytic-converters/g-sport-emissions-systems-products/ (look at their Gen2 - 400 cell)
Zrussian13
Phoenix
Even headers with high flow cats will throw a check engine light.
True and Tuners don't want anymore epa trouble so you are on your own getting rid of the light. Every once in a while I meet someone who got lucky and didn't throw a code with out cats but it's far and few between.
Mspider
Michigan
2022 GT
Man had no idea this was going on. I thought it was more of a problem with getting them to install the parts.
Zrussian13
Phoenix
Nope. Unfortunately shit hit the fan about two years ago...
