justinjohnson
- Oct 5, 2015
- League City, TX
- 2015 Mustang GT
I'm trying to find out how much power an aluminator can handle?
Agree on sleeves and MPR but I think [MENTION=13339]olaosunt[/MENTION] has burned an Aluminator under 1000.If the tune is good then an aluminator will handle 1000whp. You'll need sleeves if you want to go higher. Id go with an MPR shortblock before going with an aluminator, less money and higher quality.
I had exact same shit!! Now Im getting a sleeved block. I guess the supports cause this but I never heard about it until after.:frusty:Yup
My latest misadventure with a built block (non sleeved ) with water jacket supports .
Ended up with a crack in the valley around knock sensor.
:frusty:
Lol
Really ?I had exact same shit!! Now Im getting a sleeved block. I guess the supports cause this but I never heard about it until after.
Only upgrade is a sleeved block. I have learned the hard way to.
Any links/ info on this brace? Pics of crack on valley? What were symptoms? Wondering if I should pull whipple and lookI don't know if sleeving would have prevented crack in valley though .
MMR sells a brace for that now .
I laughed before thinking it was snake oil but my new block comes with it and at least it won't hurt (.they think my sleeve supports did )
http://www.modularmotorsportsracing...page=product_info&cPath=26_27&products_id=980Any links/ info on this brace? Pics of crack on valley? What were symptoms? Wondering if I should pull whipple and look
Interesting! I was having the false knock deal. Turned down sensors as well because my false knock was directly related to rpm where whipple started screaming. Did compression test was fine. No coolant leaking. I will pull blower to check soon as ill also be upgrading cams.http://www.modularmotorsportsracing...page=product_info&cPath=26_27&products_id=980
The crack is not visible but when you pressure test(or just running the car eventually) the coolant system you see coolant leaking .
Mine was leaking around the drivers side knock sensor.
I had been having what I thought was a false knock situation and ended up turning down the sensitivity of sensors -it could have been the start of the cracking .
I started losing coolant slowly at first and was chasing other sources .
I then started seeing more "white smoke/steam" than usual.
The coolant started leaking outside the engine eventually .
When we pulled the blower intake you could see it leaking in the valley just running the car .
