GT350 R suspension
elitex
Cumming, GA
17 GT350
What's the difference between 350 and 350 R suspension? I know the springs are different and rear sway bar is different. I am thinking about changing to the R suspension. Is there a programming difference on the MAG ride suspension? If so, can we reprogram it? Has anyone tried?
Darkane
Alberta
2016 GT350 Base
Reprogrammed due to much less unsprung weight. Also I believe the end links in the back are shorter. I think Voodoo has the R end links.
elitex
Cumming, GA
17 GT350
Thanks guys. I am thinking about going with HRE wheels. I believe they have some 19" wheels around 18 lbs. springs, sway bar and end links are cheap. The only concern I have is reprogramming the shocks.
lemers
Globetrotter
Carlisle, PA
2016 GT350
Don't the R magride react faster then the tech/track magride ?
Zitrosounds
Madison, AL
Harold
Yes! the dampeners are not the same. they look the same physically but the orifices that the fluid passes through are of a smaller diameter to include the programing that is specifically tuned to the lighter wheels. As was mentioned, rear arms for the sway bar are shorter and all the springs are shorter.
Epiphany
Global
I like to disassemble things.
I asked Eric Zinkosky and Kerry Baldori (both vehicle dynamics engineers that worked on the GT350 program) the same question about whether or not the R model dampers reacted faster. They made it clear that it wasn't about "faster" but rather they are tuned to react to a different set of parameters only.
elitex
Cumming, GA
17 GT350
So can we just buy the dampers and they'll work?
SHELBY GT350R
Dayton, OH
E36 M3
It would be great to have a definitive list on what is different in the two cars. Part number verifications, not I think this is different.
Zitrosounds
Madison, AL
Harold
Its not I think. Search the forum all the part numbers have been listed already.
Zitrosounds
Madison, AL
Harold
Zitrosounds
Madison, AL
Harold
