Gt vs gt350 base difference
DekiDoo
Glendale, AZ
2018 GT PP1
Ok, I may be wrong here.... but, the rare 2015, and 2016 GT350 base cars didn't have magna ride, am i right? If so, other than the engine, the Tremec, and obviously wheels, tires and brakes, are there any significant other, or suspension differences between PP GTs and the base GT350?
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
GT350 base suspension is still much better than the PP suspension with better springs, shocks, and sway bars. It's basically the GT350 springs with the Ford Performance Track shocks/struts. A lot of people actually add this setup to their GT's. I run GT350R springs but with adjustable Koni's as well as GT350R sway bars. Also, the 2015/2016 base GT350 did not have coolers and also had a smaller spoiler and chin spoiler.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
I know Ford sold a lot of the "base" GT 350's but an informed road warrior would not settle for anything less than an R type.
I am slowly building a base GT with "track days in mind".
WhiteyDog
WOOF!!!
Manheim, Pa.
Did the same with loads of Steeda suspension parts. I have a sh*t load installed already, and will soon have literally every Steeda suspension upgrade available installed. It handles absolutely fantastic now, and will be even better when the rest go on.
Hack
Minneapolis
Mustang, Challenger
The GT350s also have more rigid hubs than a GT IIRC.
JohnVallo
1 5 4 8 3 7 2 6
Venice, FL
racersreunion.com
'16 GT350, Shadow Black, Whipple Supercharged
YES
In the front suspension, the aluminum front hubs (Knuckles) on the GT350 are lighter, have bigger bearings, and are designed with more kingpin inclination to accommodate the change in scrub-radius needed with the wider wheels, tires. The front track width on the GT350 is 1" wider.
In the rear suspension, the rear springs on the GT350 are wound in opposite directions (R & L), requiring different lower control arms.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
The shocks are indeed different as well and I think they're actually NOT the FP shocks or whatever they are for the GT upgrade package. I think they're a tick above even.
DekiDoo
DekiDoo
Glendale, AZ
2018 GT PP1
Thanks a lot for everyone's replies. Much appreciated.
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
YES
Hi,
So if one were doing a upgrade base gt spring upgrade using the GT350 base springs, how would i go about it? how would you install? which would you order?
Thanks Anthony
