GT PP 0-60 times.
cp5899
Baton Rouge, Louisiana
Craig
2015 ingot silver gt pp
It doesn't let me make it to 60 in second. I've tried it and it's hits the rev limiter before its done with collections data or what ever is on the screen. The only way to finish the run is make the 2-3 shift.
96Mustang460cid
Tulsa, OK United States of America
Michael
2015 Ford Mustang GT w/ PP
I have a GT PP and do not have the RPM capabilities to reach 60 mph without shifting to third gear. With that in mind, I would wager a small bet that the 3.55 geared cars have the best 0-60 mph times.
If the aftermarket tunes can safely allow a few more RPM before the rev limimter, the 0-60 mph runs could be accomplished without the 2 to 3 shift and would most likely improve the times.
Have a good day!
Michael
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
I think its more of an issue with the software thats collecting the data. The numbers don't like as far as what speed is available in each gear. In other words I don't care what the TFT display says. You should be able to hit 60mph with the PP in 2nd gear.
BTW, whats max rpm with the 2015 5.0L? I assumed its 6800rpm.
Thats one thing if I ever got rid of my E92 M3 is revving that bitch out to 8400rpm, 8600rpm with software.
SilverSpoon09
Lakeland, FL
Rick
2015 GTP PP in CO / 08 CTS / 00 C-SVT
There was a post on this before but the PP hits rev limiter at 57 58.
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
Just a heads up everyone for some reason our pp cars have an incorrect speedo. Waze has me going about 2mph faster than my speedo at typical speeds. In reality it's about 2.5% off, at least on mine. Then again the dyno still showed accurate speeds so I don't know.
Dave2013M3
El Segundo,Ca
Well here is the numbers it should be..
DivineStrike
Doomsday
Charleston
Those numbers definitely aren't correct. 5th gear does not go to 150. I hit redline at about 142
Dave2013M3
El Segundo,Ca
Then Ford changed the gear ratios they are listing on their website for the 5.0L Mustang GT. Also keep in mind at 150mph there can be as much as 5% error. So 142mph could very well be 150mph.
I tried several calculators and they all came out the same.
DivineStrike
Doomsday
Charleston
Even the dyno I was on topped out in the low 140s
Tommy V
Brookly park Md
Tommy
Your not hitting 60 in 2nd gear period unless u can run the rpms out a bit more with a tune, but without the tune the only way to 60 is to shift Into 3rd.Also different states will get better times as the pp tires work much better the hotter they are, but if u really want to nail a 60 foot or 0 to 60 drag radials would really help.
SilverSpoon09
Lakeland, FL
Rick
Second is about 58... Not sure on first. I will look next time. Got a 5.3 tonight with tons of wheel spin in first but really pushed the power down through it. I think the 71 degrees helped but I think a few more degrees will help push into the 4's but I still can't see stock PP's getting 4.4's anytime soon.
cyril185
Fremont
2015 Mustang GT
I got twice 5.1 with my GT today
It's an auto with 3.55 diff and bone stock apart from FRPP Touring catbacks ...
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
1800 miles GT PP here did few highway merges on 2nd gear and hit the rev limiter right above 60 mph. The 62 mph for 2nd gear seems about right. Interestingly Car and Driver compared the gt pp with Challenger and 1le. The car did 0-150 in freaking 25.4 seconds on i believe 5th gear. Henessey has a video on youtube and they shift a little early right around 143mph to sixth gear and the car took forever to reach 150 mph. So something doesn't seem right. I don't know whats going on:shrug:
SilverSpoon09
Lakeland, FL
Rick
I have never been able to get over 60 with 2nd gear with my GT PP. I have banged the rev limiter a few times trying.
