Darkane
I can tell you the alpha platform was 28% stiffer than the Zeta. Furthering the chassis, the camaro team reduces the body in white 133lbs over the gen 5.So you don't have any numbers, measurements or data and you think I'm just going to blindly accept it? You don't have a non-biased source with comparisons? The actual performance of the two cars is very closely matched, so that is not evidence that one car has a superior chassis.
Let's say in a theoretical sense that one chassis is "better" than the other or one is "superior". Is it 1% better? 10%? Better as in stiffer? Lighter weight? More/less expensive to build? By what percentage or how many pounds lighter? How much stiffer?
Just saying something is "superior" is fairly meaningless. I think you know that. You seem like an intelligent enough guy.
Jim was intimating that the GT500 won't be made into a convertible because the Mustang chassis isn't good enough to "handle" the power. Completely false. You may want to let that go and you don't care. I don't want a GT500 convertible, but I believe that if Ford made one, the Mustang chassis would handle the power every bit as well as the ZL1 convertible handles 650 hp.
Final point, the alpha chassis has almost 4” greater wheel base than the S550, along with reduced overhangs. This reduces the pendulum effect (think 911) and increases high speed stability and balance.
Shorted wheelbases can create a feeing of playfulness and more “fun”
Which is what the mustang excels at. In numbers and performance, the alpha has it.
