Going Quad
Oakley
Lee
2022 Mustang
so then mustang has roush cat back but single pipe wither side, im trying to beef its bottom up a bit as the rectangular uk number plate makes it look a bit odd, I think im going to get a square plate and then swap the tipster quad tips to beef up its booty a bit. so the question is, do I cut black plastic to make enough room for the quad pipes and if I do that will they sit straight? or should 100% replace the lower valance for a quad version in order to get a good look, its a 2017btw
Here’s the cleaned-up translation:
So, my Mustang has a Roush cat-back exhaust, but it only has a single pipe on each side. I’m trying to make the rear end look a bit more aggressive because the rectangular UK number plate makes it look a little odd. I think I’m going to switch to a square plate and then swap the tips for quad tips to make the rear look wider and beefier.
The question is: should I cut the black plastic rear valance to make enough room for the quad exhaust tips, and if I do that, will the tips sit straight? Or should I definitely replace the lower rear valance with a proper quad-tip version to get a clean look?
It’s a 2017, by the way.
In plain terms:
He has a 2017 Mustang with a Roush cat-back exhaust, currently single exit per side. He wants the rear to look more muscular, probably by using quad exhaust tips and a square UK plate. He’s asking whether he can just trim the existing rear diffuser/valance, or whether he should buy a proper quad-tip rear valance so the exhaust sits correctly and looks OEM/clean.
neucleator
neucleator
Devon
Ford Mustang GT V8
Very kind of you dear boy, as described, ivr gone for replacement vallance and quad tips, square plate will post before and after once installed for anyone interested
Fordphanatic
Delco PA
2021Mustang GT Premium,2021 platinum f150, 2025 Super duty 6.7L Powerstroke
neucleator
neucleator
Devon
Ford Mustang GT V8
cool @Fordphanatic have you gone 2.5 - 4" there? Im going over 2.5-3" as was nervous of fitment here's the current setup and what ive ordered so will hopefully look like when its on
neucleator
neucleator
Devon
Ford Mustang GT V8
its not a huge difference and now ive put them up side by side like that im not even sure its enough to warrant the change... god dam it
