Front Wheels Custom Fitment
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
2015 GT convertible stock fronts are 9X20 40ET wants to go 11X20 +50 with 305/30r20
Will this work?
Thanks
paulm1
Northeast PA
pau
2021 GT mustang
I think it will work with spacers, 1". The 305's will fit, but if you dont want to run spacers the offset would have to be like +30
NightmareMoon
2016 Mustang GT PP w/ Voodoo
ET +26 is the normal no spacer fit for 11s
You definitely can't fit an 11 ET50 - without spacers they'll be 3/4" into the struts.
We often run longer wheel studs with a billet 1" spacer to run 11" ET50-52 w/ 305s on the front.
I have no idea on height. 19x11 w/ 305s usually will eat out part of the the fender liners.
Prodigal
OKC
2021 Mach 1
I’ve got 20x10.5 +24 with 305/30 tires on mine. No spacer with extended studs.
Bahndvr
Bahndvr
Roushcharged
Germany
My friend would like to run a square set up and he has the Shelby 20X11 +50 rims with 305/30 in the back. He would like to run them on the front too, I guess not with that offset.
Why you all running the extended studs if no spacer?
NightmareMoon
well most of us are not. The 1” billet spacer is why you would need the +1” longer extended studs.
Prodigal
OKC
2021 Mach 1
My studs are only 1/2” over factory. I like the bullet nose on them and added strength is just piece of mind. Plus they look better with my wheels and open end lug nuts.
