forscan on stereo
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I am going to install an amp myself on the factory head unit. It will save me a lot of money. I have heard people tweaking forscan settings to optimize the sound. Is the difference in sound major? Can someone share the tweaks?
McSkillet
Mobile AL
Jeff
2023 Mach 1 (6M), 2015 Holden Commodore (6M)
From what I've found the factory head unit is set to flat and all EQ adjustments are done with an aftermarket component(s) prior to the amp(s).
https://www.mustang6g.com/forums/threads/forscan-eq.171493/
MiamiGT350
S. Florida
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I can only speak for what others have tried. Disabling the EQ was reported to work to provide a fuller spectrum of sound to all channels. Whether that could be heard exclusively as increased bass on the factory rear speakers could be debated. But those that used these rear speaker outputs to feed an aftermarket subwoofer with an EQ delete said the bass was better.
On my system I have disabled the EQ and my DSP reports that the signal is flat (need no correction) going INTO the OEM amplifier. If the OEM amplifier is further attenuating the bass response on the rear I would have no way to know as I removed the OEM amp and rear speakers from my system.
All I can say after all this rambling is... try turning the EQ off. If you don't like the result revert it back to what it was. There is also something called an Epicenter that Audio Control sells. This is specifically for restoring lost bass from rolled off signal outputs.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Very good info thanks. Not going for anything earth shattering just a 50 x 4 amp
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
@Evolvd and @StangTime might have some experience here as well.
I messaged both
Thanks
Bassackwards
Nashville
2022 GT/CS convertible
You are missing the point. The idea is to remove all factory programming and to gain a flat line out signal. Several lines need editing.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I would like to learn what needs to be edited. I would like to know what to be expected sound from my relative mild amp
Bassackwards
Nashville
It has to be in combination with your amp settings and it may take a few tries to get it right. There is no standard for every vehicle because there are at least a dozen variations over the years.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Same issue. I have a 2017 mustang gt convertible. Is there anyone in the southeastern Pa, northern delaware, northeastern MD area that has forscan on their laptop that can hook into my obd2 port and turn off the ACN for me? I will pay you to do it. Anyone wanna make a quick 75.00-100.00 bucks?
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
You could do it yourself for half that.
Ferrcad
Western PA
Brian
2015 Mustang GT Convertible
As long as you have a Windows based laptop then the most expensive part is the cable... Forscan software and license are both free to download. I'm sure once your ready to go you can find the "well" documented lines to adjust sound output. I'm sure someone will probably provide once again the line(s) to change. Plus there are additional Forscan settings you may want to adjust.. Those are also documented through out the 6G forum.
Cable I have and is highly recommended...
https://www.amazon.com/OBDLink-EX-F...9775732&sprefix=obd2+usb+cable,aps,131&sr=8-9
TonyT930
Philadelphia, Pa.
Tony
Perhaps, but that doesn't answer my question or fulfill my request
