forgestar cf5 lug nut torque spec
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
USPSALIMITED
USPSALIMITED
Southern Indiana
G6 GT PP Guard
Its for your safety guys better being safe then having something occur that could have been prevented
As a service provider I think you would be nuts not to (bad pun intended).
I do it because it is very easy & gives me piece of mind.
I called Forgestar and explained that my manual said 150 ft-lbs but I was concerned because that seemed like a lot for the smaller diameter splined lug nuts I have for use with their wheels & was 50% + above their generic recommendation. The person I talked to said to torque to 150 ft-lbs, so now my book says 150 and the wheel dude says 150 but my gut likes 100, so maybe I'll do a coin flip.
Thanks to all for input.
Barrel
Hoonigan
Cars and Trucks
Split the difference and do 125?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
well I mean we here at N4SM do 100 ft lbs and so far clean track record and every client has been more then happy. But you can split the difference lol
USPSALIMITED
USPSALIMITED
Southern Indiana
G6 GT PP Guard
130 was the magic number I went with.
The interesting part was that the lug nuts felt spooky loose on the first two wheels I swapped, like maybe something in the 30 foot lb range. The next two wheels I used the torque wrench to check and they broke loose at about 65 foot pounds.
I had had a tire shop that I've used for many years put all season rubber on the original pp wheels and remount about 4,000 miles ago. Perhaps they did not torque sufficiently or perhaps I just need to get in the habit of checking lug nut torque a few times after wheels are installed.
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Weld racing wheels calls for 110 foot pounds on a 14mm 1.5 Lug nut for there RT-S wheels ..
Side_Pce
NY
2016 GT350
Despite what the Ford manual says, from the factory my GT350 was torqued to 100 ft lbs give or take 10ft lbs. I installed lock nuts when I brought it home and re-torqued all to 110 ft lbs. Old thread, just thought I should share.
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
I torque my cf5v's to 115ft/lbs, not sure I trust aftermarket wheels at OEM tq's. I know the studs are fine but just iffy about damaging the wheels.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
14mm stud requires a lot more stretch to reach the same clamping loads. Bulge seat nut has a lot of surface area, I don't recommend anything but what the spec is. In the case of some wheels which do not use a conventional nut (Weld) follow what they say. We recommend 125Ft/lbs on our 1/2" ARP studs. Do what you want but I've checked my torqued wheels and found them lose torque after a single 20 minute track session. Yes they are still tight but not to spec.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Zombie thread
Souldriver
NY
2016 - Guard GT Prem. PP
My dealer told me to do 100 ft/lb even though the handbook said 150 ft/lb.
I was going to ask about this since the manual looks to be extremely high at 150 ft/lb. I would think this may cause issues with the aluminum PP wheels too. I will most likely go to 100 and go from there probably settling around 125.
The car was at a ford dealer recently to look at brake squeal and groan so ill see what they set it to when taking it off.
Machelen
Calgary, AB
The banging four banger
did you get any result from the dealer?
Rebellion
Houston
2016 Competition Orange GT
If you torque them, don't get a cheap wrench that only goes to 150lbs...never use a torque wrench at its limit!
I torque almost everything, even the strut tower bolts and jacking rails. The only part I didn't torque was the sto-n-sho. Engineers are too picky 'bout numbers, I call up the manufacturer if I don't find the number online or the instructions.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
We use a snap on trq wrench at the shop it's awesome
