Fore Fuel System and Differences between Gen 2/Gen 3
daSNAK3
Cary, IL
Jake
2021 GT
I have a Fore L1E Fuel System on the way, should be here today... My question is how much different is installing a Fore Fuel system on a Gen 3 car vs a Gen 2 car (IF ANY), if anyone knows or has done it on both?.. reason I am asking is because there seems to be quite a few videos of installs on Gen 2 cars but not Gen 3 and I have not done a fuel system before but I think I am fairly capable as I've done everything else on the car... so I am just curious since I will probably have to hit up the videos for some help... thanks.
andrewtac
TX
mark
F250. 2020 GT 400A
I think the only difference is the connection to the DI pump. I watched a gen2 video as well. The fitting is obvious, what wasn't is it is a bit loose when connected.
LS1Coupe
florida
rich
2018 Mustang GT A10
Its fairly straight forward. It is tedius and time consuming. I did not route mine the same as they show as it pertains to the fuel rails to make it look cleaner. I also used a few different fittings to run it they way I wanted.
It is basically pump to filter, filter to HP pump, HP pump to fuel line, from the other end of that line to the next fuel rail, out of the fuel rail to the regulator, from regulator back to the tank.
There is another thread on here about it. I put up some pictures of how I routed mine, you can route the lines how you prefer.
beefcake
Bethel
2018 Ford Mustang
pretty straight forward, and again, like others said, id is the only difference.
feel free to hit us with any questions, we are fore's largest dealer!
daSNAK3
daSNAK3
Cary, IL
Jake
2021 GT
Alright cool, thanks guys. Going to install it in a few weeks when I’m on vacation from work… can’t wait.
MLAGUE
Tampa, FL
Michael
2019 Mustang GT Premium - Kona Blue
Hey Guys,
Getting ready to install my Fore 1E system onto my 2019 mustang soon and wanted to see if you came across any differences from the Gen 2 mustangs? My buddy that's helping me did his on his gen 2, but with the DI and extra injectors I wasn't sure how different this install would be. Any help is much appreciated!
@beefcake @daSNAK3
beefcake
Bethel
2018 Ford Mustang
it’ll be pretty similar other than you have the portion that goes to the direct Injection as well
MLAGUE
Tampa, FL
Michael
andrewtac
TX
mark
F250. 2020 GT 400A
The block that fits on the DI wobbles a bit, by design. I was concerned and Fore said that is normal.
HKusp
Hampton, Md.
Jason
MLAGUE
Tampa, FL
Michael
Thank you for the heads up!
beefcake
Bethel
2018 Ford Mustang
