Gen 3 Stage 2 Whipple: Knock and Fuel Quality
Discussion in 'Forced Induction - 5.0L V8 Engine' started by grabber_17, Sep 29, 2019.
  1. grabber_17
    grabber_17 Active Member
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    Hey guys,
    I installed my whipple earlier this year. Since install I have problems with knock. My question for you is how inconsistent is the fuel quality in your area? I started out with a station I have always used before the SC and I ended up getting +4 knock at WOT. I tried a QT station because of their guarantee and I would see up to +1* at WOT. I switched to a local BP and things have been good with -2* on their 93 only. I had to fill up this morning on the road at a BP about 20 miles away from home and I felt a difference. I hooked up the Nguage and saw +3.5 knock. I live in the upstate of SC and it seems like I cant find consistent 93 octane.
  2. moffetts
    moffetts Well-Known Member
    Vehicle(s):
    Black Whippled 2015 GT PP
    Nov 30, 2015
    San Mateo CA
    596
    150
    0   0   0
    CA 91 is consistently garbage.
  3. TheHydro
    TheHydro Well-Known Member
    Vehicle(s):
    2015 GT Performance Pack
    May 5, 2015
    Las Vegas
    559
    85
    Rating:
    100%
    3   0   0
    My whipple stage 3 gen 2 had problems with knock on 91 from all the stations in my area.
  4. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    I really thought that I would never see issues because we have 93 here and Whipple says their tune is set up for 91. It is really frustrating. The range is crazy I have seen as much as 20.5* of total timing all the way down to 10*.
  5. DavidHuff
    DavidHuff Well-Known Member
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,005
    194
    Rating:
    100%
    3   0   0
    Are you running a Lund Tune or you running the Whipple Tune?
    How are you monitoring your motor to show you have a Knock?
  6. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    2,664
    1,371
    Garage Profiles:
    10* at peak? Is someone pissing in your tank when you’re not looking?
  7. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    Whipple tune but I use an Nguage to monitor the knock pid and my fuel trims.
  8. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    You would think! On that pull it went +4 knock instantly so I didn't pull the whole gear, when I looked at the log the timing stayed at 10* but I don't remember what rpm I stopped. I would have to go back and look.
    Burkey likes this.
  9. Bluelightning
    Bluelightning Bluelightning
    Vehicle(s):
    Lightning Blue 18 GT PP
    May 22, 2018
    South of Houston, TX
    616
    319
    Garage Profiles:
    Fuel quality and consistency is definitely an issue. I went through the same thing with my Whipple and different stations. Mine was not a daily driver, so I just started using the same Shell station near my house that seemed to have the best quality judging by the way the car responded from all the choices around. Even doing that I still had some issues. I ended up just investing in Boostane Professional to combat fuel consistency issues and didn't have any problems after that. If you are going to keep your car on pump gas I would highly recommend.
  10. DavidHuff
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,005
    194
    Rating:
    100%
    3   0   0
    The reason I asked that question is I saw in your profile you are running a Lund Flex E85 tune also.Do you run that tune at the track?
  11. moffetts
    Vehicle(s):
    Nov 30, 2015
    San Mateo CA
    596
    150
    0   0   0
    His profile never mentions a Whipple, either, so I suspect it's just old info.
  12. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    How has your experience with boostane been? Do you have a problem with the orange residue that you see with octanium?
  13. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    Yea, I forgot to update that info. I did run a flex fuel tune from Lund before the Whipple. I will go back to them if I upgrade my fuel system for E85.
  14. DavidHuff
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,005
    194
    Rating:
    100%
    3   0   0
    Tha
    Thanks,sure hopes you get problem worked out.I always run ms109 and 92 octane mix 50/50 while I am under boost at the track just to be on the safe side.I know it is not cheap, but safe.
  15. DavidHuff
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,005
    194
    Rating:
    100%
    3   0   0
    Tha
    grabber_17 likes this.
Loading...
Share This Page
