Gen 3 Stage 2 Whipple: Knock and Fuel Quality
Discussion in 'Forced Induction - 5.0L V8 Engine' started by grabber_17, Sep 29, 2019.
  1. White5.0ut
    White5.0ut Member
    Vehicle(s):
    Jan 9, 2017
    Charlotte
    I’m in Concord/Charlotte area. I have a Lund tune with my Whipple. Mine doesn’t usual pull timing but I use only QT gas. We seem to get good quality here. I go out of my way usually to go to QT if I have to. You could try Boostane like you mentioned should boost it enough so it doesn’t pull timing.
    grabber_17 likes this.
  2. epracmetcon
    epracmetcon New Member
    First Name:
    Nick
    Vehicle(s):
    2016 GT M6
    May 16, 2019
    Rockford IL
    Fuel in my area can be inconsistent at times as well, so I have been running a boostane mix since I put mine on a few months ago.
  3. Bluelightning
    Bluelightning Bluelightning
    Vehicle(s):
    Lightning Blue 18 GT PP
    May 22, 2018
    South of Houston, TX
    617
    320
    Garage Profiles:
    I had some orange residue, but 8K miles on it with not one issue with the plugs or O2 sensors, and eliminated all my knock issues. Was also running the 3.75 pulley for 6K miles on pump gas and car was happy in all of the logs that I did, where I would get knock issues with the 3.875 pulley before adding boostane to the mix.
  4. moffetts
    moffetts Well-Known Member
    Vehicle(s):
    Black Whippled 2015 GT PP
    Nov 30, 2015
    San Mateo CA
    598
    150
    0   0   0
    I use the Lucas octane booster stuff (red bottle) which you can get on Amazon for about 80 bucks a case, which is 12 15oz bottles. Cost-wise, this is the way to go. I usually only add half a bottle and that keeps the orange residue to a minimum, plus I like to do 1 tank of straight gas for every couple bottles used. In the past, I have run full bottles with every tank and that definitely causes orange to build up as far back as the exhaust tips. I really don't think it affects performance at all, though.
  5. OP
    grabber_17
    grabber_17 Active Member
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    Thanks guys! I was starting to feel like something was wrong with my car. I guess I will be picking up some octane booster!
  6. DavidHuff
    DavidHuff Well-Known Member
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,007
    195
    Rating:
    100%
    3   0   0
    VP just came out with a new unleaded fuel additive that you should check out.They say it is safe for cats and O2 sensors.
  7. OP
    grabber_17
    First Name:
    Mason
    Vehicle(s):
    2017 Mustang GT
    Feb 9, 2018
    Upstate, SC
    I will do that, I have used VP octanium in the past and it seems to work but the orange residue was bad enough that I could see it at the exhaust tips and it left some stains on the paint that I had to polish off.
Loading...
Share This Page
